Nokia 6630 Insert Sim Hi Guys ,i Have Set 6630 ,when I Start My Phone With ( Sim Card} Its Goes Automatically In Offline Mode , If I Try To Activate Genral Profile ,it Says , Insert Sim Card, Any Body Know Whats The Hell Going In My Pone ,:) |
6630 please change the simtray sensor ic galss type near the back up battery |
1 Attachment(s) Quote:
if not ok then remove the sim ic and make jumper:) Br;) Raj |
i solve tis prob so simple jus change the battery kekeke believe it or not if ya prob exactly the same as u mention and the sim ic has been changed so solded in the ways given still cant solve jus change the battery happy tryin |
thanks man thanks man it worked. Do u have 3230 mmc diagram |
what is battery kekeke ? |
hai friends!! i have the same problem with one 6630. but it doesn't shows insert sim card when a registration failed card inserted, but it shows the problem when inserting a good card. what may be the problem ??? any clue?? |
i am unable to understand ur problem the common broblems are insert sim card and invalid sim card if u'r problem is secand one it is impossible to cure it.if it was first one then follow the above quote. |
thanks raj u made a good work |
thakuuuuuuuuuuuuuuuuuuuuuuuu |
try another battery on phone, i am sure battery problem . Bestman |
i replaced ic and its ok thank u archit |
your battery and software problem. Bestman |
replace ic juMper im use from nokia 6100 ic glas jumper after replace OFFLINE MODE PROBLEM SOLVED |
Oh! Found this out just now. My bad. I'm having a 6630 without using for past 1 year. I'm in tanjore,tamilnadu(south india). Here i gave to nokia care twice and to a private shop once. Not working yet. Pls explain what to do. Or where to contact. Atleast tell me what to tell to the shop guy so that he changes the bumper said above. Pls help. |
