Old 08-03-2006, 03:58   #1 (permalink)
Member: 275946
Thanks Meter: 8
Thumbs down Nokia 6630 Insert Sim
Hi Guys ,i Have Set 6630 ,when I Start My Phone With ( Sim Card} Its Goes Automatically In Offline Mode , If I Try To Activate Genral Profile ,it Says , Insert Sim Card,
Any Body Know Whats The Hell Going In My Pone ,
Old 08-03-2006, 04:36   #2 (permalink)
shinod's Avatar
Member: 55363
Thanks Meter: 146
6630
please change the simtray sensor ic galss type near the back up battery
Old 08-03-2006, 05:09   #3 (permalink)
..::ArchitRaj::..'s Avatar
Member: 181696
Sonork: 100.107830
Thanks Meter: 5,406
First change sim tray...
if not ok then remove the sim ic and make jumper
Raj
The Following User Says Thank You to ..::ArchitRaj::.. For This Useful Post:
Old 08-03-2006, 13:17   #4 (permalink)
Member: 101007
Thanks Meter: 27
i solve tis prob so simple
jus change the battery kekeke believe it or not
if ya prob exactly the same as u mention and the sim ic has been changed so solded in the ways given still cant solve jus change the battery
happy tryin
Old 08-03-2006, 14:59   #5 (permalink)
Member: 275946
Thanks Meter: 8
thanks man
thanks man it worked. Do u have 3230 mmc diagram
Old 08-03-2006, 16:33   #6 (permalink)
Member: 78724
Thanks Meter: 5
what is battery kekeke ?
Old 08-10-2006, 16:20   #7 (permalink)
Member: 324124
hai friends!! i have the same problem with one 6630. but it doesn't shows insert sim card when a registration failed card inserted, but it shows the problem when inserting a good card. what may be the problem ??? any clue??
Old 08-10-2006, 20:23   #8 (permalink)
Member: 328760
Thanks Meter: 4
i am unable to understand ur problem
the common broblems are
insert sim card and invalid sim card if u'r problem is secand one it is impossible to cure it.if it was first one then follow the above quote.
Old 08-10-2006, 20:24   #9 (permalink)
Member: 328760
Thanks Meter: 4
Raj
thanks raj u made a good work
Old 08-14-2006, 19:50   #10 (permalink)
Member: 155875
thakuuuuuuuuuuuuuuuuuuuuuuuu
Old 08-14-2006, 21:08   #11 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
try another battery on phone, i am sure battery problem .
Bestman
Old 08-23-2006, 09:14   #12 (permalink)
Member: 55963
i replaced ic and its ok thank u archit
Old 08-23-2006, 19:16   #13 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
your battery and software problem.
Bestman
Old 12-05-2007, 10:58   #14 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
replace ic juMper im use from nokia 6100 ic glas jumper after replace OFFLINE MODE PROBLEM SOLVED
Old 10-31-2009, 15:58   #15 (permalink)
Member: 384895
Thanks Meter: 5
Oh! Found this out just now. My bad. I'm having a 6630 without using for past 1 year. I'm in tanjore,tamilnadu(south india). Here i gave to nokia care twice and to a private shop once. Not working yet. Pls explain what to do. Or where to contact. Atleast tell me what to tell to the shop guy so that he changes the bumper said above. Pls help.
nokia 6630 insert sim ,tracks broken squaremic Nokia Hardware & Hardware Repair 0 02-13-2009 11:46
6630 insert sim with 1 sim & ok with other sim sachin_udai Nokia Hardware & Hardware Repair 1 01-14-2009 06:28
nokia 6630 insert sim Kian9159 Nokia Hardware & Hardware Repair 3 08-21-2008 11:48
Nokia 6630 Insert sim Hasan7770626 Nokia Hardware & Hardware Repair 8 09-07-2006 07:52
please, nokia 6630 insert sim cart ? eng.hamdow Nokia Hardware & Hardware Repair 9 04-19-2006 09:36
Page generated in 0.24638 seconds with 10 queries
