Old 07-15-2008, 09:41   #1 (permalink)
Member: 82711
Thanks Meter: 30
nokia 6630 memorycard inserted problem
my nokia 6630 is in mmc problem i cheaked with other memory card,and made mmc ic jumpers but problem is still, on every memory card it giving insert memory card
Old 07-15-2008, 10:12   #2 (permalink)
Member: 157053
Sonork: 100.1606219
Thanks Meter: 489
hi
power off your phone .then insert a good memory card in the phone and power and check.if phone detect the mmc means that your mmc socket is curopt.if not detect then check resistance(r=?)between each pin and gnd and compare with another good board to find fualt.
and you must change mmc ic .if not solve for last solution heat on d4800(helen) lightly or reball it.
dont forget to thanks.
The Following 2 Users Say Thank You to morteza-icu For This Useful Post:
Old 07-15-2008, 10:45   #3 (permalink)
acay's Avatar
Member: 197916
Thanks Meter: 157
cek vsim2 must present 1,8v if voltage dropup change retu..
but if vsim2 present 1,8v try change emif mmc or make jumper...
Old 07-22-2008, 10:50   #4 (permalink)
Member: 254941
Thanks Meter: 24
it may be the mmc switch pblm. check that
Nokia 6630 white screen problem! zeekapitein Nokia Hardware & Hardware Repair 2 11-02-2009 10:05
Nokia 6630 Whait Screen Problem Plz Help! jatt159 Nokia Base Band 5 ( BB-5 ) 1 12-28-2008 20:19
nokia 6630 in new problem plz auto charging mobileworld1 Nokia Hardware & Hardware Repair 1 06-25-2008 17:21
Nokia 6630 strange bluetooth problem IvailoShopov Nokia Hardware & Hardware Repair 3 01-18-2008 15:32
Nokia 6630 - Startup Failed Problem nshkw Nokia Hardware & Hardware Repair 16 11-15-2005 02:29
Page generated in 0.15691 seconds with 9 queries
