Old 09-04-2005, 18:36   #1 (permalink)
Member: 30601
Unhappy Nokia 6630 screen fading to white
Hi all... I've watch all this forum and i don't found an answer. I have a 6630 having this problem:
When i power on the phone start and work perfectly. after an indeterminate amount o time the phone stop to work and all the screen start to fade in white.
there is no way to power off with the switch.
After this when i turn on the phone appear the white screen and i cant use the phone.
The only way to rebirth it is to unmount the matherboard clean with antioxidant and remount the phone and also this don't work everytime....
I havn't any kind of tool for reflash this phone, but i made the phone flashed by a nokiacenter, they upgraded the firmware but the problem remain...
I think i'ts an hardware problem but i really cant understand what!!!!
Thanks for an answer
Old 09-05-2005, 06:20   #2 (permalink)
Member: 172221
This problem by RAP3G (D2800) defectived......
Old 09-05-2005, 08:14   #3 (permalink)
Member: 30601
mmh.... it's the core... what can i do? heat up? reball? change?
If i change it i need to reflash? (i think ^_^)
there are some other possiblities?
Thanks
Old 09-06-2005, 08:14   #4 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
yeah mostly its cpu problem, try to properly reheat it then its flash memory..in most cases like that you really needed to replace it
Old 09-06-2005, 08:34   #5 (permalink)
jarniel's Avatar
Member: 149600
Thanks Meter: 11
did you try to check your voutput, you can also reheat the tahvo power i.c. regulator. maybe it has a cold solder. this is the i.c thats regulate the power o/i.hope it will help....
Old 09-06-2005, 12:52   #6 (permalink)
Member: 30601
ok, now i'll try to ceck vout then rehot PWIC if it don't work rehot CPU and FLASH...
i hope this will work! Thanks all, i'll post my results...
Old 09-06-2005, 23:40   #7 (permalink)
Member: 132496
Thanks Meter: 34
Maybe software problem try to Format User area (Green+*+3) and dull factory.
Old 09-21-2005, 05:01   #8 (permalink)
uppwd2's Avatar
Member: 115864
Thanks Meter: 8
Hi
I have same problem.Did you solve that.
Please help me.
B.R
Old 09-22-2005, 02:29   #9 (permalink)
mccm's Avatar
Member: 173565
Thanks Meter: 71
I have one that can flash or even can charge but cannot power on,
can see local mode after or before flashing,check power swicth to 4401 ok.
please advice,thank you
Old 09-22-2005, 04:52   #10 (permalink)
Member: 172221
Check component Z4401.
Old 09-22-2005, 05:40   #11 (permalink)
mccm's Avatar
Member: 173565
Thanks Meter: 71
ic is good condition
Old 09-23-2005, 15:09   #12 (permalink)
uppwd2's Avatar
Member: 115864
Thanks Meter: 8
Hi
Yes in good condition but i recommend you to change it.
If you don't have it, just desolder it & wireing on PCB.
It will work 1000% i tested .
B.R
Old 09-23-2005, 22:21   #13 (permalink)
Registered User
Member: 59418
Thanks Meter: 6
thanks for all
good work mans
B.R.
Old 10-12-2005, 13:52   #14 (permalink)
waleed2's Avatar
Member: 85387
Thanks Meter: 78
whats your replay
please tell us what you did
n91 fading to white screen mostwanted_ray Nokia Hardware & Hardware Repair 1 03-18-2010 06:03
Nokia 7610 LCD screen fades to white eddzky Nokia Hardware & Hardware Repair 14 09-21-2008 15:57
Nokia 6085 Camera Not Working & faded to white.. amit123 Nokia Hardware & Hardware Repair 4 07-28-2008 08:13
Nokia 6630 work but with white screen emilio Nokia Hardware & Hardware Repair 6 08-15-2006 23:03
nokia 3650 screen fades away AARONIE Twisterflasher 3 10-27-2004 12:38
Page generated in 0.21706 seconds with 9 queries
