nokia 6630 white screen hi,,dear friends,,,can anybody help me,my phone is white screen ,i allready try software and change display ic,then also same problem only stand white after that off.please help me,,,,,,,,, |
if doesnt works with lcd,try to rebol uem |
try to call emergency call,then if it works,try change lcd.... |
try to rehot OMAP cpu it works 100% |
try to change the n2400 ic if it s not display prb. tell me what happens |
no sorry N4200 not n2400 |
hi can any body help i have a 6630 white screen when i ON the phone it only display black line in the lower side of the lcd and it will gone an still white screen. help me pls..... |
change displey ic br gscell |
1 Attachment(s) br try this solution i hope:) ..::Mr Fone::.. |
nokia 6630 white screen phone not booting JAF version 1.98.62 Detected PKEY: 9000171F Card life counter: 11.28% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! Fast phone flashing selected. FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 04wk47_m_v5 17-08-05 RM-1 (c) Nokia. HW version: 5440 PCI version: RFIC version: 150a160e DSP version: 04w47v22 Retu version: 32 Tahvo version: 41 Production serial number: SAI443176 Product code: 0520852 Module code: Basic production code: 0600395 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 354349007018040 IMEI spare to net: 3A 45 43 09 70 10 08 04 IMEI SV to net: 33 45 43 09 70 10 08 64 F4 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-1.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0520852 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-1\ Scanning for ini files... INI file 0520852.ini is missing. Continue searching for second ini type... Searching for default location of ini... Checking path: \Products\RM-1\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-1\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Setting local mode... Reading product code... Product Code: 0520852 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-1\ Scanning for ini files... INI file 0520852.ini is missing. Continue searching for second ini type... Searching for default location of ini... Checking path: \Products\RM-1\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-1\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Setting local mode... Reading product code... Product Code: 0520852 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-1\ Scanning for ini files... INI file 0520852.ini is missing. Continue searching for second ini type... Searching for default location of ini... Checking path: \Products\RM-1\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-1\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-1\ Scanning for ini files... INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-1\RM1_6.050308_B4.C0R PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-1\RM1_6.050308.v07 CNT Flash file: NONE APE Variant file: NONE Languages in ppm: English,Norwegian,Danish Backing up CRT data... Setting FLASH MODE Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 CMT Loader Ready Reading CMT NPC certificate... Reading CMT VARIANT certificate... Reading CMT CCC certificate... CCC not available... Reading CMT HWC certificate... HWC not available... Saved to C:\Program Files\ODEON\JAF\ProgData\35434900701804_CRT_backup _1715245.rpl Backup CRT OK! Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\354349007018040_CRT_backu p_1716245.pm Done! Backup LCK OK! Manual mode selected, version can't be checked! Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006000C192101002100 Asic Mode ID: 00 Asic EM ID: 00000341 Asic Public ID: 12D00017908D4F570EAF16FC23D9E4B60A03C660 HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000 ROM ID: F28A211FAC901AEE CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 CMT Loader Ready Operation took 0 minutes 5 seconds... APE blocks present in flash file but no APE mcu detected in phone. Aborting! |
http://img132.imageshack.us/img132/6...pg/1/w1023.png00% ok.. |
nokia 6630 white display...any solution,...pls/.... |
any solution,...plsany solution,...pls |
i think this is omap problem,,,try replace or reball |
