12-08-2008, 07:44 | #1 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 197916 Status: Offline Thanks Meter: 157 | analysis collection and solution by ACAY_TERMINAL PONSEL analysis step: * obstacle cheque at system konektor(x2001) normal * tension cheque at pin3 (aci) system konektor only there 1v normal tension must there 2.49 v analysis : -pin3 (aci) correlating problem because his tension only there 1 v solution : -remove c2011 at stripe aci/pin3, then cheque returns tension aci/pin3 normal direct there 2,49 v conclusion: -tension at stripe aci/pin3 only there 1v because c2011 broken down. . problem finished with throw away c2011... by : acay terminal ponsel |
The Following User Says Thank You to acay For This Useful Post: |
12-08-2008, 08:16 | #2 (permalink) |
Member: 197916 Status: Offline Thanks Meter: 157 | problem bluethued and can not open galery problem bluethued and can not open galery : seltest use ufs: -failed at bluetooth log flash use ufs error at cbus boot error 9 : 2nd Boot: w3_2nd.fia, Ver: 4.69.0 Fl0: 0x00000000-0x007FFFFF,0001277E,Amd 29BDS064J Fl1: 0x02000000-0x027FFFFF,0001277E,Amd 29BDS064J Fl2: 0x04000000-0x047FFFFF,0001277E,Amd 29BDS064J Fl3: 0x06000000-0x067FFFFF,0001277E,Amd 29BDS064J Algorithm: w3_amd.fia, w3_cbusb.fia, Ver: 4.69.0 Algorithm Ok, MSID: 8438B226145035684B88879ACF Decoded MSID: 3E4EBAF7-00148FFA-A9000000 Encoded FAID: 7116805F-6D3582AE-1E2F5FB4 Cbus Boot Error: 9 -----error pada ic bluetooth!!! Error Data1: 00000000: 00 96 84 38 B2 26 14 50 35 68 4B 88 87 9A CF A7 ...8.&.P5hK..... 00000010: 00 7E 27 02 00 11 01 10 00 04 01 00 7E 27 02 00 .~'.........~'.. 00000020: 11 01 10 00 06 01 00 7E 27 02 00 11 01 10 00 C6 .......~'....... 00000030: 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA EA ...u...x...{.... Error Data2: 00000000: B3 72 72 11 00 00 00 00 00 00 00 00 00 00 00 00 .rr............. 00000010: 02 00 11 01 10 00 04 01 00 7E 27 02 00 11 01 10 .........~'..... 00000020: 00 06 01 00 7E 27 02 00 11 01 10 00 C6 00 00 EA ....~'.......... 00000030: 75 01 00 EA 78 01 00 EA 7B 01 00 EA EA D3 72 00 u...x...{.....r. Before taking screenshot, expand this window ! Process Failed, Repowering Mobile -step furthermore : *repair hardware bluethuod.. *step : reball ic flash bluethued.. then cheque returns bluetooth with code #2820# his result id bluetooth direct ok!! by: acay terminal ponsel |
12-08-2008, 08:41 | #3 (permalink) |
Member: 197916 Status: Offline Thanks Meter: 157 | 5300 bluetooth can not aktif 5300 bluetooth can not aktif... measurement step: *cheque vbat at l6077 there tension 4,7v/normal -lift l6077 then obstacle cheque that aim to ic bluetooth a2 there is no obstacle absolutely, , conclusion: -stripe vbat at bga a2 ic bluetooth broken off. solution: -lift ic bluetooth then jumper foot a2 vbat to c6055 stripe vbat. . then reset ic bluetooth and test has returned bluetooth mobile!! ! by: acay terminal ponsel |
12-09-2008, 10:02 | #4 (permalink) |
Member: 197916 Status: Offline Thanks Meter: 157 | 6233 camera problem case 6233 camera at press to appear camera article ready but there is no display: measurement step makes analysis: *cheque vcam 2v8= 1,8 should there 2,8 *cheque vcam 1v8=1,8 normal *cheque vcam 1v5=1,5 normal conclusion: *vcam 2v8 problem because his tension less solution: *-jumper vcam2v8/l1000 to vaux\/c2602=2,8 BY: aCAY terminal ponsel |
The Following 2 Users Say Thank You to acay For This Useful Post: |
12-27-2008, 04:59 | #5 (permalink) |
Member: 197916 Status: Offline Thanks Meter: 157 | **analysis 6630 not charging and solution ** **analysis 6630 not charging and solution ** damage phenomenon: *try charge ponsel indicator bat direct fall, appear article not charging. . . . . measurement step makes damage analysis: step 1 : *cek output charging at konektor bat in a state of at charging there vdc = 3,6 v and in a state of stanby there voltage remainder 1,07 v. *cek voltage bsi at conektor bsi in a state of at charging there vdc = 2,53 and in a state of stanby there is no voltage.. *cek obstacle btemp to tahvo there, then cek voltage btemp at R2071 there is no tension and voltage cek at R2200 at pole that aim tahvo there vdc = 1,35v while at R2200 at pole that aim R2071 there is no voltage.. step 2 : *remove R2071, then cek return volatge at R2071 and at R2200 direct there volatge 1,35 v.. step 3 : *change R2071 then cek voltage at R2071 there volatge 0,6 v and cek has returned handphone 6630 can at charge.. conclusion: **********R2071 is broken down so that there is no tension at btemp *************** solusition : ****change R2071****** by: acay terminal ponsel |
N70 Collection of solution by PARANNJMF | PARANNJMF | Nokia Hardware & Hardware Repair | 30 | 07-05-2011 12:08 |
nokia collection of solution by chaouki GSM | CHAOUKI GSM | Nokia Hardware & Hardware Repair | 1 | 03-25-2009 20:21 |
N73 Collection of solution by PARANNJMF | PARANNJMF | Nokia Hardware & Hardware Repair | 24 | 11-12-2008 06:50 |
Please Help with GD 67 and solution by Xexu | plorijo | Panasonic | 2 | 03-11-2003 14:33 |
NOKIA 3310 5.03 and solution by Lead and Co. - some experience | black23 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-20-2001 22:30 |
