Old 08-02-2008, 11:12   #1 (permalink)
Member: 301177
Thanks Meter: 91
1600 imi shows ?????????4
i have recive a nokia 1600 its dead when i flash the phone its ok but its im i shows ?????????????4 my friend what can i do any other idea to repair this problem with out changing uem
The Following User Says Thank You to ameho0102 For This Useful Post:
Old 08-02-2008, 11:31   #2 (permalink)
Member: 535613
Thanks Meter: 9
my nokia 1208 flashing after this problem pls..........help
Getting MCU ID
MCU ID: 0x2292
FLASH ID0: 00010000 <=> Flash -> not used Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: 00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_03.720
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_03.72aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai3.72aa
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Languages in ppm: English,Dannish,Norwegian,Swedish
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_03.720
Booting phone...
MCU ID: 0x2292
BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x01000000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: d7
Loader is ready...
MSID: 843ADDD1889846B948CAB98089
MSID decoded: 3E4EBAE900D2CA35A9000000
FAID: B50082BE03CF3C976FF37F90
Operation took 0 minutes 9 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Erasing area: 017C0000 - 017EFFFF...
Erasing area: 01FC0000 - 01FEFFFF...
Operation took 0 minutes 1 seconds...
Writing...
Error cmd: 14!
Addr: 01000000
The Following User Says Thank You to pratap.nakum For This Useful Post:
Old 08-02-2008, 11:34   #3 (permalink)
Member: 535613
Thanks Meter: 9
repair this problem with j . a. f
Old 08-02-2008, 11:53   #4 (permalink)
globalsystem's Avatar
Member: 521295
Sonork: 100.1657160
Thanks Meter: 172
witch box are u used to flash you fhone?
if jaf ur problem is solved just writh backuped rpl...
1600 nokia shows Stop or not Charging abidalius007 Nokia Hardware & Hardware Repair 12 11-15-2012 11:04
1600 always show low battery. tahir-khan Nokia Hardware & Hardware Repair 8 05-17-2010 04:56
3110c imi show 123456....and contecservices help SRUCHI MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 01-07-2010 06:21
1600 Imie Patching ERROR asadnow2k Universalbox 4 08-21-2008 06:42
1600 Imie Patched asadnow2k Universalbox 7 08-15-2008 11:08
Page generated in 0.17404 seconds with 9 queries
