11-28-2006, 16:51 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: underground
Member: 113818 Status: Offline Thanks Meter: 29 | Nokia 6280 Lcd Problem I Try: 1.change Lcd 2.change Flat Cable 3.change Keypad Board 4.flash Latest Virsion But Still Same Problem,and Anyone Can Show Me Which One Display Keypad Ic Please Help.... |
02-12-2007, 22:10 | #8 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | hi i got 6280 , black lcd , phone is working other then that. i have this small black IC burned for some reason , i have removed it , still same problem , i have changed it from 6230 (same ic ? near mmc socket) problem is the same. is this my problem , or those other 2 glass IC's ? thx |
The Following User Says Thank You to TRABEL For This Useful Post: |
02-28-2007, 06:07 | #10 (permalink) |
Insane Poster Join Date: Jul 2003
Member: 33029 Status: Offline Thanks Meter: 9 | I can't get this black Ic can I replace it from 6630 glass ic near keypad connector or use jumper?Thanks in advance. Sorry for my curiousity this ic is N6050 LP3987ITLX-2.85-NOPB power supply for FM radio,why it will effect lcd as well? Last edited by ahkhoo76; 02-28-2007 at 06:22. |
02-28-2007, 07:10 | #11 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | no jumper for this IC , all jumpers i tested give me phone not turning on. you can take this IC from 6230 near mmc glass ic you will see this black ic. good luck. dont forget to replace flat cable lcd and keypad to be sure none of those is bad before replacing this ic |
05-24-2007, 16:30 | #15 (permalink) |
Freak Poster Join Date: May 2004 Location: algeria
Member: 64587 Status: Offline Thanks Meter: 39 | i ve tried to change the IC littel crystal near the camera for the camera fault now i ve a blank screen on my 6280 please is it the fault or mybe i ve overheated the board where s the probleme please my customer is angry help me |
nokia 6280 lcd problem. plz hlp | peter002 | Nokia Hardware & Hardware Repair | 11 | 01-13-2010 21:43 |
Nokia 6280 LCD | Paul Hilton | Wanted Products | 4 | 03-18-2008 01:37 |
Nokia 6280 lcd | ahmadz | Wanted Products | 11 | 03-14-2008 00:07 |
nokia 6280 lcd wanted | garcea10ro | Wanted Products | 10 | 09-05-2007 10:06 |
Nokia 6280 Lcd Problem | miecom | Nokia Base Band 5 ( BB-5 ) | 0 | 11-28-2006 15:16 |
