nokia 6700 camra stadby mode problem i was just chnge in key paid after comig this problm.and i put also old key paid still same problem when i open secrew and will luze board then camera working and when i close screw that time camera not working so give me any body gud solution thx in advance:) |
i have too.., plz . any pm or configuration file... for repair camera |
software the phone or rehot the ic |
You can processed through mxkey |
hi! i have the same problem did you repair? Quote:
any solution pliz do help tawanda |
remove camera from camera holder now put masking tape on both sides of camera and put camera back try and post result |
U can solve this problem with full charge bettry try it 1st then put masking tape bye bye |
like HUM says 1. remove camera (remove full block not only camera becouse its risky to broke the camera on 2 pieces after that its hard to fix autofocus) 2. remove flex 3. lift up the iron springs carefully to not brake something 4. put back flex cable and position it good 5. put back camera all will be fine, i fix 3 phones till now all with that solution. this problem appear somethimes coz u pull flex with the board when u open the phone so u must postion it back. |
http://img705.imageshack.us/img705/619/cam6700.jpg green is camera block red is that u have to remove and pull all block up after that disassemble the camera case |
