Old 11-11-2009, 17:29   #1 (permalink)
Member: 600726
Thanks Meter: 11
Question nokia 6700 camra stadby mode problem
i was just chnge in key paid after comig this problm.and i put also old key paid still same problem when i open secrew and will luze board then camera working and when i close screw that time camera not working
so give me any body gud solution thx in advance
Old 02-17-2010, 12:25   #2 (permalink)
saiftc2's Avatar
Member: 231662
Sonork: 1607488
Thanks Meter: 390
i have too.., plz .
any pm or configuration file... for repair camera
Old 02-17-2010, 13:32   #3 (permalink)
Member: 567450
software the phone or rehot the ic
Old 02-17-2010, 13:40   #4 (permalink)
hamada-almasry's Avatar
Member: 619738
Sonork: 100.1582811
Thanks Meter: 5,212
You can processed through mxkey
Old 02-17-2010, 18:54   #5 (permalink)
Member: 274040
Thanks Meter: 11
hi! i have the same problem did you repair?
i need a solution ,thanks man
The Following User Says Thank You to zxzxro For This Useful Post:
Old 02-20-2010, 10:07   #6 (permalink)
Member: 68534
Thanks Meter: 18
any solution pliz do help
tawanda
Old 02-20-2010, 10:24   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
remove camera from camera holder now put masking tape on both sides of camera and put camera back
try and post result
Old 02-20-2010, 11:40   #8 (permalink)
Member: 201238
Thanks Meter: 24
U can solve this problem with full charge bettry try it 1st then put masking tape bye bye
Old 03-10-2010, 12:01   #9 (permalink)
Crazy Poster
Member: 223629
Thanks Meter: 26
like HUM says
1. remove camera (remove full block not only camera becouse its risky to broke the camera on 2 pieces after that its hard to fix autofocus)
2. remove flex
3. lift up the iron springs carefully to not brake something
4. put back flex cable and position it good
5. put back camera
all will be fine, i fix 3 phones till now all with that solution. this problem appear somethimes coz u pull flex with the board when u open the phone so u must postion it back.
The Following 3 Users Say Thank You to mazymind For This Useful Post:
Old 03-10-2010, 12:27   #10 (permalink)
Crazy Poster
Member: 223629
Thanks Meter: 26
green is camera block
red is that u have to remove and pull all block up after that disassemble the camera case
The Following 2 Users Say Thank You to mazymind For This Useful Post:
nokia 6131 camra on stand by mode mlife1999 Nokia Hardware & Hardware Repair 1 09-03-2009 17:44
nokia 6110 camra problem gsm-iran Nokia Hardware & Hardware Repair 0 06-02-2009 19:35
Nokia 6500c Camra Standby Problem Solved universalunlocking Nokia Hardware & Hardware Repair 0 12-29-2008 05:55
Page generated in 0.20420 seconds with 10 queries
