Nokia 7210 -INSERT SIM??? from what is this problem? :D |
It varies from reason to other , that may prevent the SIM card from being readen by the phone ( Dirty , oxidisation , brocken track , up to semicondutors faliur ). If U still cant solve it please add some details , with U'r trials . |
chek out the pins of sim card connector for any drysoldering. if ok then chek out the tracks leading to connector for any connection failure. |
@ shark777 Start with the basics and check sim reader then work your way up download the service manual and go through it until you find the fault I reckon is proberly part R388 but thats jus a guess Regards D. |
br check the 2 smd under the sim card reader,change them and it will be ok. best reg |
1 Attachment(s) take a look,i hop this could help you... |
nokia 7210 insert simcard it could be the uem. i had this problem after changing uem on 6610 and 3100. try to rehot uem. cheers!! |
your sim card on your phone is not recongi* and you can clean ,your sim card before application or crash from your sim card can result to this problem............. i will reach you on more events that can result to this problem.. bestman. |
i guess its uem problem .. i had this problem many times ... |
