Old 09-22-2004, 11:53   #1 (permalink)
Member: 63672
Nokia 7210 -INSERT SIM???
from what is this problem?
The Following User Says Thank You to shark777 For This Useful Post:
Old 09-22-2004, 20:49   #2 (permalink)
Member: 39601
Thanks Meter: 13
It varies from reason to other , that may prevent the SIM card from being readen by the phone ( Dirty , oxidisation , brocken track , up to semicondutors faliur ).
If U still cant solve it please add some details , with U'r trials .
Old 09-22-2004, 21:08   #3 (permalink)
Member: 63703
chek out the pins of sim card connector for any drysoldering. if ok then chek out the tracks leading to connector for any connection failure.
Old 09-22-2004, 21:10   #4 (permalink)
DMD
DMD's Avatar
Member: 12660
Thanks Meter: 7
@ shark777
Start with the basics and check sim reader then work your way up download the service manual and go through it until you find the fault
I reckon is proberly part R388 but thats jus a guess
Regards D.
Old 09-23-2004, 02:44   #5 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
Thanks Meter: 108
br check the 2 smd under the sim card reader,change them and it will be ok.
best reg
Old 09-23-2004, 07:44   #6 (permalink)
Member: 39875
take a look,i hop this could help you...
Old 09-24-2004, 19:57   #7 (permalink)
Member: 65032
Thanks Meter: 5
nokia 7210 insert simcard
it could be the uem. i had this problem after changing uem on 6610 and 3100. try to rehot uem. cheers!!
Old 09-25-2004, 21:07   #8 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
your sim card on your phone is not recongi* and you can clean ,your sim card before application or crash from your sim card can result to this problem.............
i will reach you on more events that can result to this problem..
bestman.
Old 09-27-2004, 11:09   #9 (permalink)
Member: 41884
i guess its uem problem .. i had this problem many times ...
7210s insert sim Jabir27 Nokia Base Band 5 ( BB-5 ) 1 03-23-2010 09:31
7210 insert sim jln310 Nokia Digital Core Technology 4 ( DCT-4 ) 11 02-20-2009 15:23
nokia 7210 32k sim ok, but 64K sim show insert sim. vertex777 Nokia Digital Core Technology 4 ( DCT-4 ) 0 04-18-2008 14:19
7210 Insert Sim dizzu Nokia Hardware & Hardware Repair 1 03-08-2005 02:08
Page generated in 0.31629 seconds with 9 queries
