05-23-2005, 12:04 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 60
Member: 131801 Status: Offline Thanks Meter: 5 | Nokia 7210 power off after 20 seconds I have changed uem no way I have changed processor (upp) no way I have flashing mcu / ppm / new pm is there any thing i can do |
05-24-2005, 06:16 | #3 (permalink) | |
Freak Poster Join Date: May 2005 Age: 40
Member: 144350 Status: Offline Thanks Meter: 3 | Quote:
05-25-2005, 12:38 | #5 (permalink) |
Member: 131801 Status: Offline Thanks Meter: 5 | not pa I think it is not PA because the same thing without sim inside and the uem is good if it was uem it will power off 5 seconds not 20 seconds and i am sure that my uem is good i will try to change the flash ic and i will post the result soon |
05-26-2005, 14:06 | #6 (permalink) |
Junior Member Join Date: Apr 2004 Age: 47
Member: 62922 Status: Offline Thanks Meter: 1 | check first if the board is shorted which most often cause by water damaged. then isolate the problem by removing parts one by one and check every time you try to remove part so that you can pin point which is really causing you problem.. |
165o Power off after 20 seconds | abdul4gsm | Nokia Hardware & Hardware Repair | 9 | 04-18-2010 07:41 |
Nokia 3110c power off after 20/30sec with sim | Boshko_Alfa | Nokia Base Band 5 ( BB-5 ) | 10 | 02-03-2010 10:44 |
nokia 1100 power off after 30 second | rachelyna | Nokia Digital Core Technology 4 ( DCT-4 ) | 9 | 06-02-2007 16:03 |
Nokia 2300 turn off after 20 seconds | .::Munazzam::. | Nokia Hardware & Hardware Repair | 8 | 09-19-2006 05:49 |
W300 power off after 20 seconds.... | enrocas | Cruiser Suite | 1 | 08-20-2006 20:31 |
