10-13-2009, 09:57 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: BANGALORE,KARNATAKA,INDIA
Member: 677987 Status: Offline Thanks Meter: 173 | NOKIA 7210c CONTACT SERVICE when i power on phone without sim card it asks aaceept without card when press ok it shows contact service n gets off can some one help |
The Following User Says Thank You to imran_4_u For This Useful Post: |
10-13-2009, 10:00 | #2 (permalink) |
Freak Poster Join Date: Oct 2009 Location: Philippines Age: 44
Member: 1134393 Status: Offline Sonork: 100.1607778 Thanks Meter: 59 | its better you try the jaf software. try to flash that into jaf software........... |
The Following User Says Thank You to .:Baby @ngel:. For This Useful Post: |
02-13-2010, 13:54 | #6 (permalink) |
Junior Member Join Date: Nov 2009 Location: Pakistan
Member: 1156668 Status: Offline Thanks Meter: 13 | HERE THE SOLUTION FOR NOKIA 7210C CONTACT SERVICE If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!". This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...). Solution 1 (easy way, maybe not work all time, depends how phone was damaged): - write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones) - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 if still have problems, use Solution 2: - backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL - backup RPL from another working phone (same model) with SAME product code - edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL - backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM - full erase flash chip (use erase file regarding flash chip size) - flash phone (CMT, APE, ...) - upload CLONE RPL - upload ORIGINAL RPL - write full CLONE PM without fields 1,120,308,309 - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 TRY AND POST RESULTS |
02-13-2010, 15:19 | #9 (permalink) |
Freak Poster Join Date: Dec 2007 Location: india
Member: 645970 Status: Offline Thanks Meter: 157 | dear dont mind follow me :\ first take rpl backup.... then auth pm or write..... or creat factory default... if show sim security test failed..... lastely update sp lock......... or enjoy..... pm file link : http://www.MegaShare.com/1807460 i think this video may help you to solve your problem VIDEO LINK : http://www.MegaShare.com/1807489 Last edited by ashish mobile; 02-13-2010 at 15:29. |
Nokia 7210c contact service | NIMESHFONOTLY | Nokia Hardware & Hardware Repair | 78 | 08-23-2012 13:31 |
nokia 7210c contact service how to fix ? | milandhal | Nokia Base Band 5 ( BB-5 ) | 28 | 05-19-2011 17:54 |
nokia 7210C contact service | ravi..gupta | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 09-03-2009 17:56 |
nokia 7210c contact service | roklat | Nokia Base Band 5 ( BB-5 ) | 0 | 05-11-2009 23:55 |
