08-26-2010, 10:13 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: USA (Urang Sunda Asli)
Member: 958761 Status: Offline Sonork: 100.1645834 Thanks Meter: 79 | Nokia 7230 white screen. or is there another solution? |
The Following User Says Thank You to duniacell For This Useful Post: |
11-22-2010, 19:43 | #8 (permalink) |
Crazy Poster Join Date: Jun 2008
Member: 792690 Status: Offline Sonork: 2348065808196 Thanks Meter: 4 | 7230 keypad problem [B]please help me. I have these nokia 7230. the phone fell inside water. it will only power but the keys are not working. i try to change the ic i assume to be the keypad ic. after changing the phone no longer power. ple help am tiered .[/B] |
The Following User Says Thank You to great-alex For This Useful Post: |
07-23-2011, 12:29 | #13 (permalink) | |
Crazy Poster Join Date: Mar 2011
Member: 1540613 Status: Offline Sonork: papi77 Thanks Meter: 4 | Quote:
Brother I had same problem with water damaged, the phone was turning on but upper keypad was not working.I changed the flex but no result.Then checked the flex connector and lcd connector, changed the flex connector on board and it started working. Be noted that its flex connector on board is of very low quality, when u clean it with brush then it can be damaged very easily.U can get same connector from X3. Enjoy | |
08-10-2011, 12:12 | #14 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1360730 Status: Offline Sonork: [email protected] Thanks Meter: 5 | no display Sir, i have 7230 set with white display....... I changed new lcd & strip also but no result i check the connections from connector is ok plsssssssss any body have solution its better with pics plssssssss urgent.,.,.,.,.,.,.,.,.,.,.,.,.,. -------Thanks in advance........... |
