02-15-2004, 10:02 | #1 (permalink) |
Registered User Join Date: Feb 2004 Age: 45
Member: 53994 Status: Offline Thanks Meter: 1 | nokia 7250i charging IC damage pls tell me any other way to charge mobile just now i am charging battery externally. |
The Following User Says Thank You to neo_gops For This Useful Post: |
02-15-2004, 11:58 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Hi M8 In that case of U'r phone , it is a type of high tech constructabelity and it is not easy to Fix it with U'r self with any way ( if U have time read some old posts ) , it needs U to be experted , equiped , and have basic knoldges of Fixation at least !! My advice to U is to take it to an authorised service center cuase 7250i doesnt have a stand alone IC for charging !!, it is one "Big" chip ( UEM ) wich controles every thing onboard also it containes the IMEI ( serial No of the phone ) and when changes it needs to be reprogramed with a new No. So it is better to take it there but avoid unexperted persons too !! GoodLuck |
The Following User Says Thank You to Medz For This Useful Post: |
02-16-2004, 17:31 | #4 (permalink) |
Member: 53994 Status: Offline Thanks Meter: 1 | actually i have sended it to authorised service center but they told that this phone will not repair in whole india better u make external charger and charge ur battery. |
10-01-2004, 01:48 | #8 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | how come nokia authorised service center can not do it ? is it your phone water damaged ? try to clean then PCB pad .. and remove UEM , and check all line from fuse to UEM ! Quote:
1200 charging ic print damaged | sayeedkhader | Nokia Hardware & Hardware Repair | 5 | 09-26-2009 08:24 |
f480 not charge ic damaged | alb97 | Samsung Hardware Repair | 1 | 08-06-2009 09:39 |
Nokia 1110I Sim IC Print Damage | zubairok | Nokia Hardware & Hardware Repair | 3 | 08-16-2008 09:44 |
Nokia 7370 Volume Crystal Ic Damage | miecom | Nokia Hardware & Hardware Repair | 2 | 02-03-2007 17:56 |
v3 damage charging ic............ | c_ahmad79 | Motorola Hardware Repair | 4 | 08-10-2006 14:02 |
