Old 12-15-2005, 02:08   #1 (permalink)
Member: 83923
Arrow Nokia 7250i contact service flash 5.41 needed
Hi. i have a nokia 7250i in contact service
i have seen many posta saiyng that i need to flash with modified 5.41 flash but i can`t get this flash enywhere.
does any one can give me a working link for this flash or sent it to me??
Best Regards
Old 12-15-2005, 05:01   #2 (permalink)
nctrung_vn's Avatar
Member: 135671
Thanks Meter: 45
Best Regards
What your box writen Flash.
Old 12-15-2005, 05:23   #3 (permalink)
faisi's Avatar
Member: 143322
Thanks Meter: 35
use 7250 flash file to bring life in ur set................................
Tested 100% work.
BR.
GSM Mobile Lab.
Old 12-15-2005, 05:31   #4 (permalink)
Member: 189289
Fiasal saying 1000% Ok, i tried this solution many times, when you got 7250i in contact service flash it with 7250 software and when this happens in 7250 then flash it with 7250i software
working 10000% Ok
Old 12-15-2005, 06:30   #5 (permalink)
Member: 93214
Thanks Meter: 18
Best Regards
flash with 7250 with good pm file ...it will work
Old 12-15-2005, 18:00   #6 (permalink)
Member: 83923
Unhappy still not working
i flashed with 7250 flash and i get blue screen, phone seems to work fine because i can turn it on and off using the battery, but screens is all dark blue, than i flashed with 7250i flash ant when fininhed reeboted fine and appeared in the screen insert sim card, i tought it was ok, but when disconected from box and turn it on with battery appears again CONTACT SERVICE on display, i connected to box again and works fine, but with battery displays contact service like before..
Any more suggestions?
tanks
Old 12-16-2005, 06:02   #7 (permalink)
nctrung_vn's Avatar
Member: 135671
Thanks Meter: 45
The same me prolem .
What solution to do.
Old 12-23-2005, 07:01   #8 (permalink)
Member: 149576
Thanks Meter: 57
try search patch file for 7250i and 6610i
Old 12-23-2005, 07:26   #9 (permalink)
Cheater -Don't Deal with him-
mobilecraker's Avatar
Member: 142219
Sonork: 100.107814,
Thanks Meter: 368
just convert 7250i>7250.first erase whole flash of 7250i,then write flash file of 7250 n mobile should b ok.tested abt 70 times no need to search patch files of 7250i.there is no difference between 7250i n 7250 so convert it and enjoy
regards
mobilecraker
Old 12-23-2005, 15:12   #10 (permalink)
Member: 166230
7250 i Contact repair %100 ok...........
and
not CONVERTİNG 7250i to 7250
and
not change LCD
only flash in this file.....
....DOWNLOAD....
http://www.megaupload.com/?d=B63V7CU7
Old 01-10-2006, 01:46   #11 (permalink)
Member: 83923
Tanks Cellman
great Soluttion
i tryed many many sollutions in this forum
but yours was the only one that works
tanks man
Old 04-16-2006, 12:19   #12 (permalink)
devika's Avatar
Member: 78028
Thanks Meter: 90
re
great Soluttion
tanks man
pls upload the file ..............for all
Old 08-16-2007, 08:13   #13 (permalink)
Member: 332783
Thanks Meter: 10
"This file has expired due to inactivity" plz upload again
Old 05-11-2008, 14:31   #14 (permalink)
Member: 587516
Thanks Meter: 42
hi sir!! I revived the phone using the above procedures but it goes off after 40 seconds!!! any idea sir!!!! help!!! thanks!!!
Old 05-11-2008, 19:11   #15 (permalink)
CellWorm's Avatar
Member: 146067
Thanks Meter: 76
here is solution.
patch mcu with this tool and flash phone.
The Following User Says Thank You to CellWorm For This Useful Post:
nokia 7250i contact service. sonu arya Nokia Hardware & Hardware Repair 0 10-16-2009 06:43
nokia 7250i contact service emso MT-BOX 5 09-14-2007 07:08
Nokia 7250i Contact Service Realistic UFS2 + UFS3-Tornadoflasher 10 05-02-2005 17:50
nokia 7250i contact service seamusmc88 Nokia Hardware & Hardware Repair 11 10-22-2004 19:46
Nokia 7250i Contact Service After Flashing nyonyo UFS2 + UFS3-Tornadoflasher 6 05-21-2004 10:13
Page generated in 0.21870 seconds with 11 queries
