Old 07-01-2006, 07:17   #1 (permalink)
Crazy Poster
Member: 183379
Thanks Meter: 10
6600 BT not working n Open Gallery
i hv a nokia 6600 with BT not working n just "Open Gallery" running ..i hv flash it with JAP,full erase + full flash,format user area,repair bt ..after that still same n i change the BT chip for the next step ..still cant solves this problems! any solution or jumper ?
Old 07-01-2006, 09:50   #2 (permalink)
mohamedsafi123's Avatar
Member: 170244
Thanks Meter: 418
Talking
dear friend
try the farmet in menually press *+3+green button (call button)+ on/ off switch is not ok rehot the 3 flash ic solve the all fault try & replay me.................
Old 07-01-2006, 09:58   #3 (permalink)
sassouki's Avatar
Member: 136446
Thanks Meter: 9
i think the only solution is to change BT module
Old 07-01-2006, 11:19   #4 (permalink)
karemriko's Avatar
Member: 150857
Thanks Meter: 31
good work man
karemriko
Old 07-01-2006, 11:23   #5 (permalink)
Member: 206235
yup positive that your bluetooth module is definetly defective... try to change BL module
Old 07-01-2006, 11:42   #6 (permalink)
Member: 302271
solution for your problem
I think first of all you should change your bt device and also check for that your mobile bt device is still working or not.both are in good condition there after you should use nokia 6600 pc suite to establish connection .
I f you dont have pc suite cd then I will provide you the software for that
ok till then
bbabye..
Old 07-01-2006, 19:51   #7 (permalink)
Member: 79823
Thanks Meter: 26
just format the fone or if you realy have to replace th BT divice on fone you can also use 3650 BT divice on 6600 but i think formating it is the solution or reflow it with good soldring paste
Old 07-02-2006, 09:14   #8 (permalink)
roopesh_500's Avatar
Member: 100579
Sonork: 100.1578318
Thanks Meter: 106
formatting, than rehot the bt module if it is a minor problem then the bt will work 100% ok
i have tried it
Old 07-02-2006, 09:39   #9 (permalink)
Softway's Avatar
Member: 143889
Sonork: 100.1584685
Thanks Meter: 341
allredy posted on same topic. so why u guys discussing here? go to correct thread. ull find all usefull info there.
NOKIA 6600 Bluetooth not working,cannot access Gallery bogy16 Nokia Hardware & Hardware Repair 21 08-09-2009 08:15
6600 bt not working after flashing saleeha WD2 & APE (Symbian Phones) 14 04-18-2008 02:18
Not able to open gallery in 6670 naseer_10_1980 WD2 & APE (Symbian Phones) 3 12-16-2006 08:34
new 6230i bt not working kklasa Nokia Digital Core Technology 4 ( DCT-4 ) 2 01-05-2006 15:31
Page generated in 0.18589 seconds with 9 queries
