Old 06-23-2006, 12:37   #1 (permalink)
Member: 81868
Thanks Meter: 7
nokia 7260 dead water damage
Hello friends my problem is dead phone 7260 water damage procedure steep : clean ultrasonic and clean pcb phone work power on problem is insert sim not reader all sim rehoot ic sim reader not resolved remove ic sim connect wire point ic same point 1100 not connect wire ground pin sim and ground not resolved and clean sim connetor , use ufs press ui setting not solution my problem please solution thanks regards
Old 07-02-2006, 03:59   #2 (permalink)
Member: 81868
Thanks Meter: 7
Hello problem insert sim solved change ic small sim used damage 1100 nokia and rehooting uem flux hot air problem solved phone network is ok problem is keys and volume taste is taste ok not working please is possible jumper z400 emi filter is ic same 8310? working key 1-2-3-4-5-6-7-8-9 and send -not thanks regards
Old 07-02-2006, 13:23   #3 (permalink)
Member: 81868
Thanks Meter: 7
Hello problem solved change z2400 ic used ic keypad same 5210 phone is ok keys and volume botton warter damage ic not solution clean hot air solution is change ic thanks
Nokia N97 DEAD water damaged, can i repair? powerplay83 Nokia Hardware & Hardware Repair 5 05-13-2010 13:48
nokia 5200 dead water damage tarsem Nokia Hardware & Hardware Repair 3 07-23-2009 12:49
Nokia 6680 Stark In Nokia Logo After Water Damage chronic Nokia Hardware & Hardware Repair 4 11-19-2007 00:38
n70 dead water damage Y2ksalman Nokia Base Band 5 ( BB-5 ) 6 12-31-2006 07:51
Nokia 7260 after water damage balouch Nokia Hardware & Hardware Repair 1 02-03-2006 13:58
Page generated in 0.29944 seconds with 8 queries
