nokia 7360 says no access/no network found hi please I have 2 nokia model 7360 here with me ; 1 says no network found when I use manual searching. 2nd one gets network for abou 40sec.and desapears again. and when I use manual searching it says no access. what do I do please. for your help is urgently needed.Thanks. :confused: |
Replace the PA IC brother.................:) |
Bro,check the PA ic 1st if not ok change the PA ic,if still not ok replace uem |
brother no access means PA ic problem so change the PA ic |
m8, try to reheat RF processor & filters near it. Check connection/ reheat antenna switch &/or replace RF PA. |
@winxp_sp2 ur solution is incorrect this is not proper solution dont try this solution |
masters i also have 7360 it says no network, pls wats the way out can anyone help...:confused: |
also have 7360 it show no network can any one help |
i wnt to know no network found of nokia 7360 |
