06-09-2007, 19:10 | #1 (permalink) |
Registered User Join Date: Apr 2007
Member: 483748 Status: Offline Thanks Meter: 47 | Nokia 7610 Contact Retailer 00000000: 00 24 00 C0 05 04 01 C2 ) .THEN I FLASHED PHONE WITH LATEST FIRMWARE BUT NO RESULT. THEN I REBALL BOTH FLASH IC'S RESULT SAME NO IMPROVEMT AT ALL.WHAT I DO NOW. IN SHORT I DONE ALOT ALREADY NOW I NEED UR GOOD SUGESSTIONS . \\\\\\\THANX /////// |
The Following 2 Users Say Thank You to xtremeburaq For This Useful Post: |
06-11-2007, 11:29 | #4 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Hong Kong
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | Find the reason of faulty by selftest then use the right way to repair it, for example if that's flash checksum failed then you can reflash it, there are too many reasons for contact retailer problem. post the selftest result then see what we can help for you. |
06-20-2007, 20:56 | #8 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: guangzhou,CHINA & delhi,INDIA
Member: 399779 Status: Offline Thanks Meter: 125 | Quote:
06-20-2007, 23:50 | #9 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | IT IS 3 METOD 1 ereasing manualy 2 flash ic,but in ufs 3 window 3 adress Fl0: 0x00000000-0x00FFFFFF,00ECDDFE,Sam K8S5615ETA Fl1: 0x02000000-0x02FFFFFF,00ECEEFE,Sam K8S5615ETB Fl2: 0x04000000-0x047FFFFF,00EC2250,Sam K8S6415ETB reflash latest version if not ok metod 2 2 change flash ic small k8s6415eta or b reflash now but if not ok replace old small ic flash (own previus small flasl ic) metod 3 change uem .flash now .write any rpl asic5 good luck |
11-01-2008, 19:23 | #12 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: Faisalabad, Pakistan Age: 41
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | 7610 Contact retailer try to flash and flash ok but still same try format but fail manually format ok but still same problem self test resuld external RAM failed and here is log of JAF. Plz give working solution ASAP. Waiting for your kind response. Kind regards, Vicky Quote:
04-30-2009, 06:38 | #13 (permalink) |
No Life Poster Join Date: Oct 2007 Location: MX-Key and me ...The Best
Member: 617692 Status: Offline Thanks Meter: 306 | Contact retailer is ofthen software problem. After flashing it does not do "format user area" job or do not complete "Factory default".... then format manualy.. steps for formating: press 3 + *(star button)+ send button(green button) and powr on the phone..Hold on these three buttons until formatting starts.... 100000000000000000000000000000% working... if this does not working then hardware problem... Note:First chek software do not hardware |
The Following User Says Thank You to farihabest For This Useful Post: |
Nokia 7610 contact retailer | ricter | Nokia Hardware & Hardware Repair | 19 | 09-04-2007 06:30 |
nokia 7610 contact retailer | kenzhe | Twisterflasher | 1 | 11-15-2005 16:46 |
7610 contact retailer | --==Dixon==-- | WD2 & APE (Symbian Phones) | 15 | 11-07-2004 05:19 |
Help 7610 contact retailer | alif30 | Griffin | 2 | 07-14-2004 16:53 |
