Nokia 7610 Dead..PLZ Help Hi, when i turn on the phone Show "start-up failed Contact retailer" ... I try formating Manual, Formating On JAF and flashing the phone with lates flash on JAF and The same problem.. I Try re heat on flash ic then phone dead an show this message : Getting MCU ID MCU ID: 0x1201 i try flashing and show: error booting and re heat Phone didn't answer PLZ HELP!!! What Can I Do?! |
80%upp problem, 20% flash chip problem chek both abject good luck |
Thank you rez7am But Can I Change Flash IC Without Change UPP?! |
y u can .first take out fl2 then check on ufs/jaf.what error it shows if the same then u have also take out fl0,fl1 ic .then check again if it show flo with no id. then ur problem is in flash if same error then reball upp. |
i will try and tell u |
