01-07-2009, 18:46 | #2 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 706300 Status: Offline Thanks Meter: 147 | " if u mean local mode failed then u hav to work on most of things firstly u hav to use higher version for flashing ( software) & check the result if the problem remains same then u hav to work on bootic, flash ic, uem & upp the suspects in hardware case, which gets clear after proper checking i.e, voltage etc, thanx" |
nokia 1200 flishing ok no power on... (ANSWERED) | jamaletw | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 03-20-2011 02:25 |
Nokia n90 flash ok and power with white back lcd | Diana Mobile | Nokia Hardware & Hardware Repair | 2 | 03-26-2009 07:01 |
nokia 7610 flash ok pwoer ok | ahmed nokia | WD2 & APE (Symbian Phones) | 3 | 09-11-2006 22:39 |
