Old 11-21-2007, 15:27   #1 (permalink)
nomi's Avatar
Member: 78440
Thanks Meter: 56
nokia 7610 lcd leds problem
hi to all, i have 7610 with lcd leds problem. i also change the led ic and quil and lcd conector and every thing about leds. and lcd too. but same no lights in lcd keypad light is working. please tell me any woking solution for my problem.??????????
thanks in advance
Old 11-21-2007, 18:02   #2 (permalink)
Member: 282073
Thanks Meter: 13
thanks in advance
check da conponent with 3 legs near light ic .test with multimeter upside leg to vbatt c if circuit broken.(juz make jumper if broken)
Old 11-21-2007, 20:17   #3 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
Trace the +V LCD light to LCD connector then through LCD and make a jumper directly to LCD pin. because your LCD connector do not contacts very well to your LCD....
The Following User Says Thank You to capri For This Useful Post:
nokia 3120c lcd led problem ron_ron Nokia Hardware & Hardware Repair 6 02-08-2010 17:35
nokia 3120 lcd led problem abrarmultani Nokia Hardware & Hardware Repair 1 06-11-2008 12:02
7610 lcd leds problem adnanali Nokia Hardware & Hardware Repair 3 10-07-2007 10:47
7610 lcd leds light on, right after batt insert? mccm Nokia Hardware & Hardware Repair 0 07-31-2006 16:36
nokia 7610 lcd display problem nomi Nokia Hardware & Hardware Repair 2 07-22-2006 16:00
Page generated in 0.19520 seconds with 10 queries
