03-13-2006, 21:49 | #1 (permalink) |
Junior Member Join Date: Sep 2005
Member: 177348 Status: Offline Thanks Meter: 1 | Nokia 7610 not power up.. I have a 7610 but not power up,the motherboard is perfect and the phone isn't water damage.. i have try attach with ufs, but i cannot write/read pp, pm, uem, and i cannot obtain info..but i can flash it complete any solution? for me is damaged the part where is storage the imei etc but i don't know for solution thanks for any reply |
03-14-2006, 14:24 | #2 (permalink) |
Insane Poster Join Date: Jun 2005 Age: 39
Member: 153278 Status: Offline Thanks Meter: 2 | hey man pls stop... wen ur mobile has 1st boot is ok .. but no power off.. u cant info @twister-ufs-tornado.. just upon ver. flash it every thing ok it has no any hardwear folt my dear.. |
03-14-2006, 15:46 | #4 (permalink) | |
Member: 177348 Status: Offline Thanks Meter: 1 | Quote:
i have used the mcu c1 and 04 for ppm from last version in ufs support i flash the phone but when finish not power up and i cant read info from phone... how can i obtain the log? tonight I post the screenshoot of ufs | |
03-14-2006, 16:00 | #5 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | you have flash the problem, i would have love to know , what happed to phone before flashing?, you have to try doing some checking on your phone . 1. check battery again. 2.check your phone casing again , if any short cirurt occupied inside phone. i will post you more soon, today . bestman |
03-14-2006, 19:35 | #7 (permalink) | |
hi the phone is dropped and not power on... the motherboard is not damage i check it and is intact, no water damage. the battery is good, tested with another nokia the lcd and keypad is intact tested on another 7610 if i maked info by ufs the box stand in "scanning operate mode" and then pass in idle 0% with nothing on the screen.. if i make check by ufs the phone on the screen i read 1st boot ok,wd2, upp: 1081 rebooting mobile if i flash i can flash mcu and ppm this before i flashing and now then flashing how i check for short circuit i don't have diagram or manual | |
03-15-2006, 05:31 | #8 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 234955 Status: Offline Thanks Meter: 19 | hi, if you can post log or screenshot it could help solving your problem... try to use C2 MCU version. erase flash first. if still dont power, erase flash again and flash with C1 MCU |
03-17-2006, 11:20 | #10 (permalink) |
Member: 61294 Status: Offline Thanks Meter: 49 | this problem is an hardware solution . i believe that , short - circuit is on phone. you need to check again. if the phone is not responsing to your flashing cable , can i suggest steps to this.(reading ) if your phone was flashed, and your phone dead. i can help you . please, i need some answers to this question what operating system are you using? remember,to check your phone interface again, try intacting cable interface well and try flashing again. bestman |
The Following User Says Thank You to bestman For This Useful Post: |
03-17-2006, 11:45 | #11 (permalink) | |
Freak Poster Join Date: May 2002 Location: dubai
Member: 11945 Status: Offline Thanks Meter: 76 | Quote:
regards. | |
03-17-2006, 12:09 | #12 (permalink) | |
i used xp for operating system if you intended this... the cable is intact because in another 7610 work fine have you got a service manual for 7610?.. level 1-2-3-4 | |
03-17-2006, 12:34 | #13 (permalink) | |
then i try to resolder for change where i find it? i must buy another 7610 faulty? no? | |
box not finding phon and also not powering up phon | joni_rajpura | SpiderMan | 8 | 01-31-2010 14:02 |
Nokia 6230 does not power up and not charging | mobileunlockers | Nokia Hardware & Hardware Repair | 0 | 11-26-2006 20:54 |
Nokia 3220 not powering up | james* | Nokia Hardware & Hardware Repair | 2 | 04-07-2006 09:46 |
BE$ after not closing with screws not powering up | Burnt Cobba | Alcatel & TCL Old Models | 2 | 08-09-2002 10:05 |
