nokia 7610 phone start-up failed help me pls 1st network problem changes pfo notwork but flash phone per phone start-up failed.contact the retailer help me pls |
jaf ,do >>>file syetem format,until,jaf format ok. if u use ufs,press format user are,>>>>>until format user area ok. br |
do number formatting then try factory resetting in jaf or ufsthen formatit |
bro try hand formet power key .call key.*key. 3key |
flash and unlock with mxkey |
If u are using the UFS. 1. Erase the handset useing erase flash option. 2. Flash the handset with latest version file 3. Write a good pm file in it. 4. Format user area. 5. At last in U.I. options do last 3 (reset user lock, init simlocks and reboot in Normal Mode). |
only format user area with ufs |
bro change data ic and and hand flash set 99%ok |
Brother first post your info log then we can help you |
contact rertailer in WD-2 is only due to user area just format it problem will be solved it is pertinenet to mentioned here that if contact retailer is due to hardware than never will solve through software format/flash |
i use jaf box info Powering the phone... Reading... MCU SW version: V 7.0642.0 18-10-06 RH-51 (c)NMP HW version: 6003 PCI version: UEM version: 144 UPP version: 4225 Production serial number: DDE722549 Product code: 0514521 Module code: 0202215 Basic production code: 0511637 Flash code: Order number: 1234567 Long production SN: ATO: h????????????????????????????????????????????????? Default SN type: h????????????????????????????????????????????????? IMEI plain: 357087008976173 IMEI spare to net: 3A 75 80 07 80 79 16 07 IMEI SV to net: 33 75 80 07 80 79 16 37 F3 PDC: 4E 54 54 4A 50 12 34 56 Master Code: 2323106504 Phone type: RH-51, Software version: 7.0642.0, Language Pack: 26 User code: 12345 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0514521 Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\ Scanning for ini files... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.33 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Bahasa Mal.,Bahasa Ind. (Apac-3) Done! CHK Getting MCU ID MCU ID: 0x1081 FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... |
help me pls............ |
hmm....The problem will be solved only with formatting. Brother just format with UFS or use the formula to format the phone. step 1 Turn off the phone Press and hold the three buttons *(star),3(three) and yes button(green button) and then Turn on the phone. Format will start. If format does not start with formula then apply the two formulas first: step 2 *#7780# *#7370# then start from step 1 |
or try this with jaf : -conect phone to jaf box -phone mode,set to test mode -do file system format,until>>>>jaf format ok. br. |
only do flash & formate user area not ui seting 100% working post result |
