Old 03-30-2009, 20:55   #1 (permalink)
Member: 465668
Thanks Meter: 23
nokia 7610 startup failed contact the retailer
nokia 7610 startup failed contact the retailer,flash,erase flash but ui settinng not done yi setting failed,format user area done any soloution
Old 03-30-2009, 21:17   #2 (permalink)
Member: 969467
Thanks Meter: 37
i think that is flash ic problem bro ,change it , 32 mb first
good luck
The Following User Says Thank You to slim_melta For This Useful Post:
Old 03-30-2009, 21:18   #3 (permalink)
mazmaz1's Avatar
Member: 339455
Sonork: 100.1589401
Thanks Meter: 85
Hello
first check software (that you do it)
hardware
rehot big flash chip(ape chip) or reball this chip
rehot(reball) SD ram chip.
post result
Old 03-30-2009, 21:30   #4 (permalink)
Member: 969467
Thanks Meter: 37
Originally Posted by mazmaz1 View Post
Hello
hardware
post result
do not rehot sd ram br in these problem just do in flash ic ,
ram damage only 10% bro
sorry hope you understand
Old 03-30-2009, 21:37   #5 (permalink)
Cheater -Don't Deal with him-
Member: 686535
Sonork: 1592667
Thanks Meter: 108
Hi
chek config key
rpl
Old 03-31-2009, 05:09   #6 (permalink)
Member: 521368
Thanks Meter: 4
format = power+press & hold call+*+3
The Following User Says Thank You to le nghia For This Useful Post:
Old 03-31-2009, 05:30   #7 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 765
Just Hand Format
* + 3 + Call + Put On....
The Following User Says Thank You to suraj9860607689 For This Useful Post:
Old 03-31-2009, 05:32   #8 (permalink)
syl phone's Avatar
Member: 320823
Thanks Meter: 1,592
[format = power+press & hold call+*+3]
SOME TIME THIS method working for this problem.u can try this way.
Old 07-24-2011, 12:08   #9 (permalink)
Member: 1238726
Thanks Meter: 2
yes its 100% work good solution
Old 07-27-2011, 11:15   #10 (permalink)
unuunu's Avatar
Member: 1623262
Sonork: 100.1621312
Thanks Meter: 96
just hand format brother....*+3+call+power. i tested many times...good luck
The Following User Says Thank You to unuunu For This Useful Post:
Old 10-04-2011, 15:23   #11 (permalink)
m.awais.as's Avatar
Member: 1284347
Sonork: 100.1592292
Thanks Meter: 976
i have nokia 7610Nokia 7610 phone startup failed contact the Retailer
i have nokia 7610
i am 3 time hand formate
* 3 send button
but phone did same condition
Old 10-04-2011, 16:48   #12 (permalink)
Member: 1331830
Sonork: 100.1625861
Thanks Meter: 4
try use ufs.format user area with 2x same time
example
complete 00.45
complete 00.47
complete 00.47
until get twice same time...
7610 Phone Startup failed contact the retailer Misbahullah HWK 10 09-13-2009 20:21
7610 phone startup failed contact the retailer .::ADNAN440::. Nokia Hardware & Hardware Repair 5 08-03-2009 16:35
7650: Phone startup failed. Contact the retailer problem jignesh_1000 Griffin 9 09-25-2005 15:11
7650: Phone startup failed. Contact the retailer. Greatgonzo Griffin 7 06-24-2004 11:39
Page generated in 0.35715 seconds with 8 queries
