Old 04-27-2008, 09:59   #1 (permalink)
mouradb3's Avatar
Member: 498262
Thanks Meter: 16
nokia 7610 steel phone start-up failed
hi guys i need solution for this nokia 7610 i have done him flash 10 times also erase flash but steel phone start-up failed contact the retailer
what can i do
Old 04-27-2008, 10:07   #2 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
what can i do
try with format manually (ok+*+3)
if still same problem,check flash ic and uem ic just repaleced it
br
joni_yang
Old 04-27-2008, 10:37   #3 (permalink)
mouradb3's Avatar
Member: 498262
Thanks Meter: 16
replace it and you think that's easy
Old 04-27-2008, 10:55   #4 (permalink)
.::AssAnovic.::'s Avatar
Member: 162611
Thanks Meter: 315
This the probleme hardware please search in forum for good solution after write the good RPL
Old 04-27-2008, 11:02   #5 (permalink)
shabooksa's Avatar
Member: 451103
Thanks Meter: 49
my dear brother i repaired it many times
rehot flash and ram ic if still the problem it is 100% uem change uem and write rpl it willbe ok dont forget first u must check imei
Old 04-27-2008, 11:25   #6 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Dear friend . . . ,
This topic many times discuss in this forum.
Alway's use SEARCH button.
And just do clear UI setting. If IMEI is OK.
Post result.
Old 04-27-2008, 12:34   #7 (permalink)
mouradb3's Avatar
Member: 498262
Thanks Meter: 16
it's not flash problem i will rehot the ic and i will post result
Old 04-27-2008, 12:50   #8 (permalink)
mehedi.h.j's Avatar
Member: 324042
Sonork: 100.1578276
Thanks Meter: 3,504
Many times, It was tested by me.....(Use 100w lamp For rehot 100% safe)
Old 04-27-2008, 13:24   #9 (permalink)
mouradb3's Avatar
Member: 498262
Thanks Meter: 16
we will try it we will see
Old 04-27-2008, 13:46   #10 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
check IMEI..................
Old 04-27-2008, 13:55   #11 (permalink)
Member: 283763
Thanks Meter: 102
format with ufs and full factry settings ok
Old 04-27-2008, 15:47   #12 (permalink)
Member: 678649
Thanks Meter: 3
6670 contact retailer solution using the HWK
Its just the software faulty..
follow this step:-
1.make sure the phone is in local mode
2.set 'full factory default'
3.turn to normal mode
4.turn to local mode
5.do 'format user area'
Do it step by step.If failed,try again.i've done it many times.
The Following User Says Thank You to Chan Ho Nam For This Useful Post:
Old 04-27-2008, 17:16   #13 (permalink)
Cheater -Don't Deal with him-
Member: 265129
Thanks Meter: 281
what can i do
Rehot the RAM's or chang
Old 04-28-2008, 13:06   #14 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
bro... i try 2 help u 2 solved ur problem...n u say like this?
and 4 me replaced all the part is very easy why not?
br
joni_yang
Old 04-28-2008, 13:46   #15 (permalink)
Member: 622382
Thanks Meter: 201
search the many soulation here
Nokia N95 rm159 phone start-up failed contact the retailer. faizanbhatti94 Nokia Base Band 5 ( BB-5 ) 6 04-08-2010 08:47
Nokia N95 8g PHONE START UP FAILED CONTACT THE RETAILER biscotte64 Nokia Base Band 5 ( BB-5 ) 9 08-22-2009 20:54
nokia N95 8GB phone start-up failed problem after unlock with zuela samirtelecom Nokia Base Band 5 ( BB-5 ) 5 04-29-2009 14:50
Page generated in 0.22200 seconds with 9 queries
