Old 10-26-2008, 20:29   #1 (permalink)
Member: 856796
Thanks Meter: 40
nokia 7900,,disassembly needed
anyone please help,,
i need nokia 7900d disassembly print or video,,your help will be very much appreciated,,thanks to all
Old 10-26-2008, 21:09   #2 (permalink)
Member: 461923
Thanks Meter: 2,020
..well.."the key" is under display...the LCD is fixed with sticker..so you need to put under display with a syringe little technical alcohol for dissolve the glue..after that you will be able to remove the LCD..after ...is simple....succes...
The Following User Says Thank You to stefani For This Useful Post:
Old 10-26-2008, 21:40   #3 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Hehe welcome to NOKIA 7900
Opening instructions here attached
http://rapidshare.com/files/15782524...l1_l2.rar.html
Max_B
The Following User Says Thank You to Max_B For This Useful Post:
Old 11-14-2008, 01:35   #4 (permalink)
Member: 900142
Hi Max_B,
is it possible to reup this manual?
Thanks in advance
Old 11-14-2008, 07:46   #5 (permalink)
.:HuyPQ-GSM:.'s Avatar
Member: 119323
Thanks Meter: 25
Link not work!
Fix, please!
Old 11-14-2008, 08:08   #6 (permalink)
Member: 770823
Thanks Meter: 4
Here is 7900 prism service manual L1&2, with dissasembly manual
http://rapidshare.com/files/16360913...l1_l2.pdf.html
Old 11-14-2008, 09:38   #7 (permalink)
Member: 900142
Thanks Heinz :-).......
Old 01-24-2009, 10:49   #8 (permalink)
Member: 290819
hello, i need nokia 7900d disassembly, Link not work, Fix, please.
The Following User Says Thank You to conrad9210 For This Useful Post:
Old 12-09-2009, 11:00   #9 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
Need a valid link to 7900 disassembly .
Old 05-30-2010, 11:47   #10 (permalink)
Member: 235448
Thanks Meter: 18
file not found man canu upload in megaupload or somewhere
thanks in advance
nokia 7900 '' chargar no suptead '' azizall4u Nokia Hardware & Hardware Repair 12 01-07-2011 14:29
nokia 3250 disassembly video,needed farry Nokia Hardware & Hardware Repair 4 07-11-2007 22:17
nokia 6021 disassembly instructions needed ablebizsol Nokia Hardware & Hardware Repair 0 05-30-2007 03:29
nokia 7200 DISASSEMBLING video NEEDED mohammed Nokia Hardware & Hardware Repair 4 11-07-2004 23:25
Page generated in 0.31324 seconds with 9 queries
