09-08-2004, 00:54 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Peh Bhooti, Pakistan Age: 41
Member: 49896 Status: Offline Thanks Meter: 14 | Nokia 8310 showing CONTACT SERVICE after flashing!! After i flashed it i put it on n it worked fine but when i took the battery out again CONTACT SERVICE came up. I have re-flashed the phone and even re-flowed the UEM but still the same, some one says i might need to replace the Flash IC but im unsure, what should do?? |
09-12-2004, 02:59 | #9 (permalink) |
Freak Poster Join Date: Jan 2003 Location: Canada Age: 44
Member: 19689 Status: Offline Thanks Meter: 1 | I have this problem with a 6100 too...flahs and do everything nothing happen/Finally the problem is the PCB board is bent. Did u drop the phone or has the phone been dropped, or heated too much? |
09-19-2004, 13:48 | #12 (permalink) |
Product Supporter Join Date: Oct 2002 Location: Philippines/Shenzhen, China Age: 58
Member: 16816 Status: Offline Sonork: 100.42691 Thanks Meter: 105 | before doing a uem change, i just want to hear you guys your opinions. i flashed 8310 with griffin and ufs3,old and new version,also UNLOCKED IT MANY TIMES, factory reset and format users area,both flashers shows local mode and power on while connected it cable insert sim shows but still contact service if battery is connected. used also some erase flash and still the same status, confirming its uem corrupt eeprom side? anyone had 100% solution? |
10-15-2004, 11:04 | #14 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Fahad Al Salem, Kuwait Age: 42
Member: 63385 Status: Offline Thanks Meter: 3 | Ey try to reheat ur flash IC, maybe its have cold contacts. Be sure to apply an ample amount flux so dat the IC will be properly aligned... Then flash again!... i repaired a lot of 8310 with the same problem... Pls posts for result. Chill |
10-15-2004, 11:39 | #15 (permalink) |
Member: 16816 Status: Offline Sonork: 100.42691 Thanks Meter: 105 | i made it! the reason of my contact service 8310 isin the uem,after changing it it is now ok. test unit with griffin and you will see what will fail. |
Need urgently help - 3600s show contact service after flash | jomafi | Cyclonebox | 11 | 09-19-2009 11:20 |
Nokia 7250i Contact Service After Flashing | nyonyo | UFS2 + UFS3-Tornadoflasher | 6 | 05-21-2004 10:13 |
8310 contact service after flash | GYZMO | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 08-01-2003 17:49 |
