03-10-2004, 20:00 | #1 (permalink) |
Freak Poster Join Date: Nov 2003 Age: 45
Member: 43545 Status: Offline Thanks Meter: 7 | nokia 8310 shows handfree sing without h/f dear i had a nokia 8310 ..........they shows handfree without handfree.......i reball UPP & UEM .......& i also change L106 & L107.......pl any tell me wat i do........thanks //Tanmay// |
03-11-2004, 08:12 | #4 (permalink) |
Member: 43545 Status: Offline Thanks Meter: 7 | @GsmBlade Dear i replace the bottom connector & i try without bottom connector......but still same .....& ......@ Own dear line ok .....how much volt we pl tell me ..........thanks ANYOTHER IDEA>>>>>>>>> // Tanmay // |
03-12-2004, 00:26 | #9 (permalink) |
Freak Poster Join Date: Feb 2004 Location: jordan Age: 47
Member: 54916 Status: Offline Thanks Meter: 58 | just small inf for all the 8310 must put the handsfree connector evry time to test coz the handsfree normaly close if u remove the base(connector) it will give signal means the handsfree plug in so u have to make sure that the connection internal of bord is ok? |
03-12-2004, 19:16 | #12 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Well now U have one of two , the path from R155 to the UEM , ( or U can bridge R155 "the socket end" , to coil L104 "the one related to the socket Sw". Also check if one of the small capasitorsC102,C111,and C157 is shorted to the Grnd , also R159 , C161 ,and R165 too. They forms the pathway of the volt wich comes from the UEM to the " Xear +ve " pin , and returns to the UEM through a leef Sw in the socket wich is disconnectes when U plugs in the handfree jack. Then the UEM comes ! clean it ,if U like doubleface on it , but I prefaire reflow or reballing is better. By the way I forgot to ask did the headset speaker works ? GoodLuck Br Last edited by Medz; 03-12-2004 at 20:45. |
03-13-2004, 05:39 | #13 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Mauritius
Member: 5585 Status: Offline Thanks Meter: 8 | Once I got a problem like this and when I checked the pcb I found one pin turning and making contact on another pin on the LCD to pcb connector and when I put it right the problem solved. Check the LCD to PCB connector pins. |
03-13-2004, 22:11 | #15 (permalink) | |
Member: 54916 Status: Offline Thanks Meter: 58 | Quote:
but ur headset will not work when plug it | |
nokia 6500c show usb mode without cable | makrad | Nokia Hardware & Hardware Repair | 14 | 03-26-2011 10:04 |
8310 always show handfree | gsmsharzad | Nokia Hardware & Hardware Repair | 10 | 09-26-2009 08:43 |
nokia 8310 handfree option??????? | Rizwan ch08 | Nokia Hardware & Hardware Repair | 0 | 09-13-2008 13:27 |
P910i shows HANDFREE without handfree.solution??? | blaiseid | Sony Ericsson Hardware Repair | 4 | 07-19-2008 13:07 |
Nokia 8310 showing CONTACT SERVICE after flashing!! | MC Harami | Nokia Hardware & Hardware Repair | 15 | 10-15-2004 14:08 |
