Old 07-24-2009, 14:19   #1 (permalink)
Member: 254086
Thanks Meter: 24
nokia N70 its giving this errer when i m flashing the phone
sir i have one dead n70 i was flashing with jaf it can boot with jaf n it can give the info but when i m flashing its it giving this errer
Powering the phone...
Reading...
MCU SW version: V 05wk07v48.1
28-08-07
RM-84
(c) Nokia.
HW version: 6061
PCI version:
RFIC version:  150a160f
DSP version: rolf_05wk07v29p1
Retu version: 32
Tahvo version: 52
Production serial number: SVJ912805
Product code: 0541860
Module code:
Basic production code: 0542519
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 353269017399209
IMEI spare to net: 3A 35 62 09 71 93 29 00
IMEI SV to net: 33 35 62 09 71 93 29 10 F2
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2343300000000000
Provider: Orange;United Kingdom
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN
Block 2:
Lock 1: OPEN
Block 3:
Lock 1: OPEN
Block 4:
Lock 1: OPEN
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0541860
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\
Scanning for ini files...
INI file 0541860.ini is missing. Continue searching for second ini type...
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-84\
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: ?
Done!
APE Variant file: NONE
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V01
APE Variant file: ?
Backing up CRT data...
Setting FLASH MODE
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files\ODEON\JAF\ProgData\35326901739920_CRT_backup _610247.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\353269017399209_CRT_backu p_611247.pm
Done!
Backup LCK OK!
Manual mode selected, version can't be checked!
Booting phone...
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101002200
Asic Mode ID: 00
Asic EM ID: 00000352
Asic Public ID: 0680010CE26D515118D7A2D64A63FD9178389A1B
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
CMT Boot Ready
CMT Loader Ready
Operation took 0 minutes 5 seconds...
Sending CNF Data...
APE blocks present in flash file but no APE mcu detected in phone. Aborting!
Phone Type:
Phone Type:
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Saved to C:\Program Files\ODEON\JAF\ProgData\35326901739920_CRT_backup _613247.rpl
Backup CRT OK!
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\353269017399209_CRT_backu p_614247.pm
Done!
Backup LCK OK!
Preparing for downgrade...
Phone ready for downgrade!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Operation took 0 minutes 4 seconds...
Sending CNF Data...
sir what could be the problem
any solution sir
Thank u
Old 07-24-2009, 14:53   #2 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
try to reball or replace flash combo memory,,,,,,,,
if still not solved bad luck u,,,,,,,,,,
last solution is omap
Old 07-24-2009, 14:57   #3 (permalink)
jhoesteve's Avatar
Member: 539557
Thanks Meter: 193
try this brother
The Following User Says Thank You to jhoesteve For This Useful Post:
Old 07-24-2009, 16:05   #4 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.try to jaf........
..mark (skip ape)...& flash......
..after flash now set power on but whitescreen hanging..
..now apply this jumper..& enjoy it.......
The Following 2 Users Say Thank You to mahbubalfa For This Useful Post:
Old 07-24-2009, 17:29   #5 (permalink)
Mehdi Ghorbani's Avatar
Member: 103931
Thanks Meter: 31
The end this is OMAP processor fault..
nokia 6500c its giving errer in flash shakil143 Nokia Hardware & Hardware Repair 6 11-10-2010 06:22
When i flash nokia 6680,its show this. omary Nokia Hardware & Hardware Repair 3 01-23-2010 11:26
nokia 1200 its giving this errer when Flashing shakil143 Nokia Hardware & Hardware Repair 1 11-30-2009 12:45
how do i sholwe this problem when i m Downloding sons in ipod its giving this errer patelfaizu iPhone 2 / iPhone 3G / iPhone 3GS 0 09-18-2009 08:04
nokia 1209 its giving this errer flashing time patelfaizu Nokia Hardware & Hardware Repair 1 07-28-2009 08:15
Page generated in 0.19633 seconds with 10 queries
