Old 05-29-2012, 12:43   #1 (permalink)
Member: 733869
Thanks Meter: 10
nokia asha 200 display problem....
display white light only plz give me solution.......
Old 05-29-2012, 12:58   #2 (permalink)
Member: 1761678
Sonork: 100.1615439
Thanks Meter: 369
first check incoming outgoing ok
Old 11-05-2012, 04:29   #3 (permalink)
Member: 960720
Thanks Meter: 8
Post asha 200
i hav asha 200 . display light problem .....
can anyone giv me display conn. jumper ways
Thanks in advance
Old 11-05-2012, 04:37   #4 (permalink)
Member: 1645520
Sonork: gsm forum
Thanks Meter: 2
change ic disply only
Old 11-05-2012, 04:40   #5 (permalink)
Member: 1645520
Sonork: gsm forum
Thanks Meter: 2
display white light only plz give me solution. the first change ic disply only
Old 11-09-2012, 11:57   #6 (permalink)
PARMATMA's Avatar
Member: 201107
Sonork: 100.1576954
Thanks Meter: 726
Try to flash with MXKEY
Select as dead usb.
Driver: nmwcdc, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.46
EBL version: Quantum_Bootloader_10.46_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: 35934604319672
RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35934604319672_ back.RPL)
Processing file: rm761__11.81.mcusw
Downloading item CODE:rm761__11.81.mcusw_ebl_psi.fls, num block: 4, size: 25.25 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.391 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.422 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 2.125 s
Erasing area 0x40280000-0x41A7FFFE ...OK
Programming completed in 45.328 s
Checksum verified (0xBACD)
Processing file: rm761__11.81.ppm_mel
Downloading item CUSTackage_mel.ppm_ebl_psi.fls, num block: 1, size: 4.73 MB
Erasing area 0x41A80000-0x41F3A35A ...OK
Programming completed in 8.953 s
Checksum verified (0x2145)
Processing file: rm761__11.81.image_mel_059J5F9
Downloading item CUSTackage_mel_059J5F9.image.fls, num block: 1, size: 15.63 MB
Erasing area 0x421C0000-0x43E1FFFE ...OK
Programming completed in 30.797 s
Checksum verified (0xACC8)
Total time for flashing process(boot+erase+write) was 7 min 49.312 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Phone not found, retrying ...
Nokia USB Phonet detached.
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 38A96FA4
New device connected: nmwcdnsuc\Nokia USB Flashing Generic
Connection status: EHCI:HUB:HUB:USB 1.10 Full-speed
Error opening !
New device connected: nmwcdc\Nokia USB Phonet
Connection status: EHCI:HUB:HUB:USB 2.00 Full-speed
Nokia USB Phonet ready.
Phone type: RM-761 (Nokia 200)
SW version: V 11.81 20-08-12 RM-761 (c) Nokia
Imei plain: 35934604319672-8
Product code: 059J4P7
Language Pack:
- not available.
Imei net: 35934604319672
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
B.R.
Kalpesh Varia
The Following User Says Thank You to PARMATMA For This Useful Post:
Old 01-30-2013, 03:27   #7 (permalink)
Member: 1876097
show me nokia asha 200 display ic
The Following User Says Thank You to stanoset For This Useful Post:
Old 02-01-2013, 07:11   #8 (permalink)
Member: 1243722
Thanks Meter: 12
Old 02-01-2013, 10:12   #9 (permalink)
Member: 1724142
Sonork: 100.1650870
Thanks Meter: 17
can u make call or not if u can make and receive call
rehot the ic
if u cant make call and u don't have permission try to flash it with mxkey
Old 03-04-2013, 05:12   #10 (permalink)
Member: 1243722
Thanks Meter: 12
same prablam bro please help
Old 03-08-2013, 10:53   #11 (permalink)
hossnemamun's Avatar
Member: 324750
Sonork: 100.1590437
Thanks Meter: 301
Dear Bro can you try this.
may help you.
Best Regards
Hossne Mamun
The Following User Says Thank You to hossnemamun For This Useful Post:
Old 08-20-2013, 06:22   #12 (permalink)
Member: 2005577
Sonork: felixm20
I av rehot the 2 ic, change the screen clip, asha 200 stll showing white screen what to I do again? Please help me out
Old 09-13-2013, 10:27   #13 (permalink)
Member: 1722119
Sonork: CAMA.GSM
Thanks Meter: 5
nokia asha 200 display track problem
i need nokia asha 200 display track help problem ways..pls anyone give me solution.
The Following User Says Thank You to CAMA.GSM For This Useful Post:
Old 04-09-2016, 08:09   #14 (permalink)
Member: 2557463
nokia 200 white display solution / i am checking starting sound / starting sound ok .display conecter ok , why?
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.41057 seconds with 8 queries
