Old 06-25-2012, 17:04   #1 (permalink)
Crazy Poster
Member: 894785
Thanks Meter: 8
Thumbs up Nokia asha 200 hang
my nokia asha 200 hang problom i also update the phone but no response any body help me plz
thanks
The Following User Says Thank You to super_mobile577 For This Useful Post:
Old 06-25-2012, 17:37   #2 (permalink)
dharmeshslnk's Avatar
Member: 385162
Thanks Meter: 598
just small heat on flash ic...
Old 07-02-2012, 12:56   #3 (permalink)
Crazy Poster
Member: 894785
Thanks Meter: 8
rehot cpu set 10000% ok i tested it
Old 07-02-2012, 15:06   #4 (permalink)
Member: 580309
Sonork: NO HAVE
Thanks Meter: 21
just change lcd 120% ok
Old 09-29-2012, 05:53   #5 (permalink)
Member: 1506624
i also have a nokia asha 200.
I've done firmware upgrade/downgrade and still the same problem
hows that?
Old 09-29-2012, 18:03   #6 (permalink)
Member: 626865
Nokia asha 200 hangs
Backup d memory card,then format the memory card,then scan the backup files for any form of virus,then insert d files back to the memory card,insert it to the phone and check it,it will work fine
The Following User Says Thank You to chimaclifford For This Useful Post:
Old 10-13-2012, 05:30   #7 (permalink)
fahad ali khan's Avatar
Member: 1771086
Thanks Meter: 2,410
NO Bro this problem Hardware ..100% i Tested change Clack IC 1000%
The Following User Says Thank You to fahad ali khan For This Useful Post:
Old 10-13-2012, 05:38   #8 (permalink)
fawad85's Avatar
Member: 301242
Thanks Meter: 201
post tested solution who have done with own hand solution only....
The Following User Says Thank You to fawad85 For This Useful Post:
Old 10-13-2012, 05:44   #9 (permalink)
Member: 1771086
Thanks Meter: 2,410
Asha 200 Softwear ok But Mobiles hang probelm solved
replay most bro [email protected] +923002226088
The Following 3 Users Say Thank You to fahad ali khan For This Useful Post:
Old 10-13-2012, 08:28   #10 (permalink)
Member: 1569142
Thanks Meter: 4
from where i get clack ic
Old 10-13-2012, 08:48   #11 (permalink)
Member: 1771086
Thanks Meter: 2,410
U get any one mobiles in NOKIA Caock IC
Old 10-30-2012, 11:29   #12 (permalink)
Member: 1172949
Sonork: felix
Thanks Meter: 7
it only works 4 a while after changing clock ic. is there any permanent solution? i'm desperate for this solution. thanks
Old 10-31-2012, 08:27   #13 (permalink)
rizwankhan8670's Avatar
Member: 1497980
Thanks Meter: 1,266
bro flash ic small heat 100000000000000%%%%%%%
The Following User Says Thank You to rizwankhan8670 For This Useful Post:
Old 11-02-2012, 18:43   #14 (permalink)
Member: 1172949
Sonork: felix
Thanks Meter: 7
i need a view of flash ic cos i cant figure which is flash ic
Old 11-09-2012, 12:58   #15 (permalink)
PARMATMA's Avatar
Member: 201107
Sonork: 100.1576954
Thanks Meter: 737
Sometime software, try this first.
http://forum.gsmhosting.com/vbb/8919604-post6.html
Page generated in 0.19208 seconds with 10 queries
