-   Nokia Hardware & Hardware Repair (http://forum.gsmhosting.com/vbb/f148/)
-   -   Nokia asha 200 hang (http://forum.gsmhosting.com/vbb/f148/nokia-asha-200-hang-1496082/)
super_mobile577 06-25-2012 17:04
Nokia asha 200 hang
my nokia asha 200 hang problom i also update the phone but no response any body help me plz
dharmeshslnk 06-25-2012 17:37
just small heat on flash ic...
super_mobile577 07-02-2012 12:56
rehot cpu set 10000% ok i tested it
PERVEZKHAN 07-02-2012 15:06
just change lcd 120% ok
aero123455 09-29-2012 05:53
i also have a nokia asha 200.
I've done firmware upgrade/downgrade and still the same problem
hows that?
chimaclifford 09-29-2012 18:03
Nokia asha 200 hangs
Backup d memory card,then format the memory card,then scan the backup files for any form of virus,then insert d files back to the memory card,insert it to the phone and check it,it will work fine
fahad ali khan 10-13-2012 05:30
NO Bro this problem Hardware ..100% i Tested change Clack IC 1000%
fawad85 10-13-2012 05:38
post tested solution who have done with own hand solution only....
fahad ali khan 10-13-2012 05:44
Asha 200 Softwear ok But Mobiles hang probelm solved
replay most bro [email protected] +923002226088
amit.r. 10-13-2012 08:28
from where i get clack ic
fahad ali khan 10-13-2012 08:48
U get any one mobiles in NOKIA Caock IC
zobas 10-30-2012 11:29
it only works 4 a while after changing clock ic. is there any permanent solution? i'm desperate for this solution. thanks
rizwankhan8670 10-31-2012 08:27
bro flash ic small heat 100000000000000%%%%%%%
zobas 11-02-2012 18:43
i need a view of flash ic cos i cant figure which is flash ic
PARMATMA 11-09-2012 11:58
Sometime software, try this first.
http://forum.gsmhosting.com/vbb/8919604-post6.html
Page generated in 0.29940 seconds with 5 queries
