Bro where is the clack ic in pcb pls help :( |
1 Attachment(s) this problem cames from software sometime also from hardware . so try to full flash d unit first with latest firmware . if not solve then proceed to hardware repair. first try to remove d two marked chipcaps then check , if same replace B3000 (32.768Mhz clock crystal) . if still same replace B7100 (26Mhz clock crystal) then check . if again still same problem try to reball or replace cpu . post result |
rehot cpu tested for me....... |
@fahad ali khan , don't edit my posted picture . I advice u to post ur's one !! @ all , who have hang problem , check my above posted solution & reply here . |
rehot flash ic only no hit cpu 10000% ok i tested it shujahmobile gujrat pk |
refelow upp............................. |
asha 200 hang problem change Clock crystal 100% Quote:
thank u so much mr Fahad Ali khan my problem solves 100% ok solution |
My asha 200 has display problems it does show graphics Just white. |
where i can find clock crystal ?? thx |
asa 200 led lcd help..... |
I have same problem but i'm not luck after change clock...sombdy have the other solution ?? please.... |
