what is clack ic i dont understand |
tested for me 4x hang up asha 200..only crystal clock ic change only.. |
thanks re hot flash ic ok00000000000 |
I need image for clack IC nokia asha 200 |
I've do change the clock ic but still same problem sir..... |
How wil I identify the clack ic |
i think clock ic as described in post is rtc( real time clock) not clock crystel .........crystel is for network section both do the prb of hang.. mostly by rtc the prb created in any handset of nokia or samsung or any china mobile too.... i solved many with this what not always many time firmware, cpu and flash create the hang prb. |
change clack or crystal 32,768khn rehot ic power then flash doneeeeeeeeeeeee |
my Nokia Asha 200 white screen problem solved after replacing lcd problem came when phone fell solved in Rs.250 in India. |
in pakistan pric e Rs. 320 |
100% solution, tested.......................... thanksgsm forum |
bro remove r22 and check agin |
This is hardware problem, Re hot CPU Carefully. I did this 4 or 5 times with nokia 200 phones, All are working good. 100% |
first step -flash -rehot cpu + flash + change clock -reflash this is my own ways. . |
