Old 02-21-2013, 10:20   #1 (permalink)
eman_sayed55's Avatar
Member: 850081
Thanks Meter: 15
nokia asha 305 only vibration
the phone was water damaged i clean the pcb now it only vibrate,is this somehow related with software?i have also flashed the phone but in same condition
Old 02-21-2013, 11:11   #2 (permalink)
Member: 1887732
Thanks Meter: 9
last version bb5 best donglebox...try it....
Old 02-22-2013, 01:00   #3 (permalink)
Member: 850081
Thanks Meter: 15
this is hardwareeeeeeeeeeee
Old 02-22-2013, 01:29   #4 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 5,865
nokia asha 305 vibra
try trick image below
Old 02-22-2013, 01:57   #5 (permalink)
Member: 1886939
Sonork: 100.1650305
Thanks Meter: 77
just check bsi line battery connector
Old 02-22-2013, 02:20   #6 (permalink)
Member: 881000
Sonork: 100.1614181
Thanks Meter: 8
rehot processor and flash with latest version
Old 02-22-2013, 14:01   #7 (permalink)
Member: 850081
Thanks Meter: 15
any solution else
Old 09-19-2013, 08:18   #8 (permalink)
Member: 1751164
bsi line ok and i flash latest version but now it only vibrate any solution plez
The Following User Says Thank You to sanjari mobile For This Useful Post:
Old 09-19-2013, 19:11   #9 (permalink)
Crazy Poster
Member: 521984
Thanks Meter: 16
just clean the bord nicly.put soldring past n use heat gun.check lcd jak also.
The Following User Says Thank You to Mr.funny For This Useful Post:
Old 09-19-2013, 19:30   #10 (permalink)
ashishsingh's Avatar
Member: 1424659
Sonork: 100.1648352
Thanks Meter: 142
Remove camera & check not solve ur problem remove gun nosel rehot cpu&flash ic I am tested
The Following User Says Thank You to ashishsingh For This Useful Post:
Old 10-18-2013, 14:04   #11 (permalink)
Member: 1414949
Sonork: 100.1626290
Thanks Meter: 30
bro check lighting fault it might be damaged or check bsi line it might fault
The Following User Says Thank You to Jeethesh For This Useful Post:
Old 10-18-2013, 17:41   #12 (permalink)
Member: 1682075
Thanks Meter: 13
this 4vibra not work
Old 10-18-2013, 17:42   #13 (permalink)
Member: 1682075
Thanks Meter: 13
its bsi way check bsi way
Old 12-18-2013, 06:42   #14 (permalink)
Crazy Poster
Member: 2009099
Thanks Meter: 6
sir give me light ic image please
Old 03-19-2014, 06:52   #15 (permalink)
Member: 1983681
Sonork: iogregu
change bluethooth ic 100% ok
Page generated in 0.40960 seconds with 8 queries
