nokia Asha 311:with sim card mobile goes off Nokia Ahsa 311 without sim card mobile is ok but with sim card mobile goes off. I have flash with 7.36 version of software but phone condition is same. Phone goes off while using sim card. need some solution. |
1 Attachment(s) dial 112 or 911 without sim & check phone goes off or not , if mobile getting off during this emergency calling then problem should be in rf section . in this case measure current consumption in rx-tx mode. if current consumption is too high then PA may faulty . second thing , if mobile not off during emergency calling then check vmmc voltage (1.8v-2.8v) at marked chipcaps (check in attach picture) . if vmmc voltage not getting then remove that two marked chipcaps . if still same then we need to replace pearl (power ic) . post result |
wer iz nd wat iz..rx-tx? plz help meh wen dial 112 or 911 phone off |
Brother .:SARCAR:. is right your problem is PA (Power Amplifier). Change the PA then check.. Post result. |
bro i will change alsho phone off..but i will pa open set on |
urgant bro plz help meh |
nokia asha-311 rm-714 7.37 is available infinity best try this. or check imei |
all ok its pa fult an some componance...but wen i put pa phone off.. |
dear problem contarct service sim ock data corapt |
Nokia Ahsa 311 without sim card mobile is ok but with sim card mobile goes off Change PA and try 100% Solution |
i m also facing many sets same problems so if u tested plz share picture |
http://forum.gsmhosting.com/vbb/atta...1&d=1376941771 |
nokia c6-01 i m also facing same problems |
