Old 08-19-2013, 15:51   #1 (permalink)
Member: 1030555
Sonork: ********
Thanks Meter: 24
Thumbs up nokia Asha 311:with sim card mobile goes off
Nokia Ahsa 311 without sim card mobile is ok but with sim card mobile goes off. I have flash with 7.36 version of software but phone condition is same. Phone goes off while using sim card. need some solution.
The Following User Says Thank You to yuganta For This Useful Post:
Old 08-19-2013, 20:49   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,122
dial 112 or 911 without sim & check phone goes off or not , if mobile getting off during this emergency calling then problem should be in rf section . in this case measure current consumption in rx-tx mode. if current consumption is too high then PA may faulty .
second thing , if mobile not off during emergency calling then check vmmc voltage (1.8v-2.8v) at marked chipcaps (check in attach picture) . if vmmc voltage not getting then remove that two marked chipcaps . if still same then we need to replace pearl (power ic) .
post result
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 09-04-2013, 13:42   #3 (permalink)
Member: 1471030
Thanks Meter: 11
wer iz nd wat iz..rx-tx?
plz help meh wen dial 112 or 911 phone off
Old 09-04-2013, 15:17   #4 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
Brother .:SARCAR:. is right your problem is PA (Power Amplifier). Change the PA then check.. Post result.
Old 09-05-2013, 09:15   #5 (permalink)
Member: 1471030
Thanks Meter: 11
bro i will change alsho phone off..but i will pa open set on
Old 09-06-2013, 13:45   #6 (permalink)
Member: 1471030
Thanks Meter: 11
urgant bro plz help meh
Old 09-06-2013, 13:55   #7 (permalink)
Member: 1111588
nokia asha-311 rm-714
7.37 is available infinity best
try this.
or check imei
Old 09-07-2013, 14:37   #8 (permalink)
Member: 1471030
Thanks Meter: 11
all ok its pa fult an some componance...but wen i put pa phone off..
Old 09-07-2013, 14:50   #9 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 130
dear problem contarct service sim ock data corapt
The Following User Says Thank You to MR.MAMUN For This Useful Post:
Old 09-09-2013, 19:11   #10 (permalink)
saman kumara's Avatar
Member: 1077541
Thanks Meter: 66
post result
your right bro,i already check this 1000000000000000% ok
The Following User Says Thank You to saman kumara For This Useful Post:
Old 01-16-2014, 01:58   #11 (permalink)
Member: 880819
Change PA and try
100% Solution
Old 01-16-2014, 02:16   #12 (permalink)
Member: 1545437
Thanks Meter: 12
i m also facing many sets same problems so if u tested plz share picture
Old 01-16-2014, 04:07   #13 (permalink)
Member: 1077541
Thanks Meter: 66
you try this?
Old 01-16-2014, 04:24   #14 (permalink)
narayan pathak's Avatar
Member: 1864020
Sonork: 100.1624750
Thanks Meter: 44
nokia c6-01 i m also facing same problems
Old 01-16-2014, 17:13   #15 (permalink)
Member: 1077541
Thanks Meter: 66
chenge power amp after post result
Page generated in 0.36461 seconds with 8 queries
