07-02-2010, 02:21 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Neo-SANA
Member: 292106 Status: Offline Sonork: 100.1582885 Thanks Meter: 116 | Nokia 5030 strange keypad problem Anyone come across this strange problem?..How u solve pls pls. |
The Following User Says Thank You to thomp4pal For This Useful Post: |
07-02-2010, 07:31 | #2 (permalink) |
Insane Poster Join Date: May 2010 Location: kerala: nilambur
Member: 1300401 Status: Offline Sonork: 2+2=4 Thanks Meter: 16 | dear brother keypad ic shorting . check your ic or inmother board ic print check it . 100 %%% ic or ic print problem . |
The Following User Says Thank You to firosnbr For This Useful Post: |
07-02-2010, 20:03 | #4 (permalink) |
Registered User Join Date: Aug 2009
Member: 1087294 Status: Offline Thanks Meter: 252 | check all point of keypad ic on board for shorting not change keypad ic make keypad ic jumper after five jumpers check keypad if ok make another jumper and check after every jumper i solved that type of prob in 1110 two times i already changed two ics but result same then i make jumpers of ic try it i think your prob solved must reply |
10-01-2010, 14:57 | #10 (permalink) |
Freak Poster Join Date: May 2007 Location: india,tamilnadu
Member: 500885 Status: Offline Thanks Meter: 77 | bro change the k pad ic stil the same bro chk keypad track in the pic no solve it just rehot the cpu |
The Following User Says Thank You to m.bala For This Useful Post: |
10-01-2010, 15:01 | #11 (permalink) |
Insane Poster Join Date: Mar 2010 Location: ..::INDIA::..
Member: 1261393 Status: Offline Sonork: ..::KISHANGANJ ::.. Thanks Meter: 13 | 4 nokia 5030, pls change volume switches, this causes 4 kepad probleme. |
The Following User Says Thank You to teamviewer For This Useful Post: |
12-05-2010, 13:01 | #12 (permalink) | |
Freak Poster Join Date: Feb 2010
Member: 1247853 Status: Offline Thanks Meter: 71 | Quote:
just change all side keys........ur problem will solve.....1000000000% | |
04-16-2011, 14:16 | #15 (permalink) |
Junior Member Join Date: Feb 2009
Member: 974973 Status: Offline Thanks Meter: 2 | anjanreddy Banned Join Date: Oct 2009 Posts: 6 Member: 1130798 Status: Offline Sonork: no Thanks: 2 Thanked 10 Times in 3 Posts nokia 5030, pls change volume switch thanx bro u r righet |
