11-16-2012, 05:23 | #9 (permalink) |
Registered User Join Date: Aug 2009 Location: mumbai
Member: 1098397 Status: Offline Thanks Meter: 80 | my flashing log Insert USB Cable to Switched OFF Phone and Power ON IF_USB: XGOLD213 IF_SBL: XGOLD213, Ok IF_EBL: Quantum_Bootloader_2.5_M1S1.2.5, Mode: CC FL_ID : EC000024, Samsung Unknown 512Mb MCU FLASH BUNDLE: rm607__06.15.mcusw Flash File: rm607__06.15.mcusw_ebl_psi.fls Erase Area: 0x40000000 - 0x4001FFFE, Erased: 00:00 Write Area: 0x40000000 - 0x4001FFFE, Written: 00:00 Erase Area: 0x40040000 - 0x4007FFFE, Erased: 00:00 Write Area: 0x40040000 - 0x4007FFFE, Written: 00:00 Erase Area: 0x40080000 - 0x4009FFFE, Erased: 00:00 Write Area: 0x40080000 - 0x4009FFFE, Written: 00:00 Erase Area: 0x400A0000 - 0x4019FFFE, Erased: 00:04 Write Area: 0x400A0000 - 0x4019FFFE, Written: 00:02 Erase Area: 0x40400000 - 0x41BFFFFE, Erased: 01:37 Write Area: 0x40400000 - 0x41B7FFFE, Written: 00:54 PPM FLASH BUNDLE: rm607__06.15.ppm_a Flash File: package_a.ppm_ebl_psi.fls Erase Area: 0x41C00000 - 0x421FFFFE, Erased: 00:15 Write Area: 0x41C00000 - 0x41F88D16, Written: 00:08 CNT FLASH BUNDLE: rm607__06.15.image_a_0595346 Flash File: package_a_0595346.image.fls Erase Area: 0x42200000 - 0x43E5FFFE, Erased: 00:47 Write Area: 0x42200000 - 0x42D5FFFE, Written: 00:24 Erase Area: 0x43E60000 - 0x43F3FFFE, Erased: 00:03 Flashing Done: 04:24 ShutDown Done |
01-07-2013, 13:13 | #12 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 666540 Status: Offline Thanks Meter: 354 | I have same problem in C1-01 hang with white light no incoming & out going call, I have flashed with higher version, checked all display tracks & changed lcd but problem still the please give tested solution experts... Here is log... Product Serial Number: D1609DCAI Product Code : 0595598 Basic Production Code: 0585582 Long Production SN : 0 PPM SW Version : Vp arc6.10 19-10-11 RM-607 (c) Nokia MH MCU SW Version : Vp arc6.10 19-10-11 RM-607 (c) Nokia HW Version : 2001 RFIC Version : 96 LCD Version : TPO Content Pack Version : Content: mh_0595598 Vp arc6.10 19-10-11 RM-607 (c) Nokia ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000003000B ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : FAILED MASTER_CODE : 6071475321 PHONE_MODE : TEST |
