nokia c2-01 contact service hi guys.i have a nokia c2-01 with contact service error after nokia logo.i flashed with lkatest version but no luck.here is log MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C08175B0 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0000684D Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Processing MCU file: rm721__11.40.mcusw [BB5,XSR 1.6] size: 28.58 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 149000147E2E59408B5417939047EA85A8C7A227 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT ROM ID: 67E82268F29CEA60 Loading CMT secondary boot code SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Update server code loaded. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: EDE6E82 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35741804051776_CE RT.rpl). CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 37.69 MB CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-0009FFFF] CMT FLASH,MuxOneNAND area [000A0000-0025FFFF] CMT FLASH,MuxOneNAND area [003E0000-005DFFFF] CMT FLASH,MuxOneNAND area [005E0000-010DFFFF] CMT FLASH,MuxOneNAND area [01EC0000-01EDFFFF] CMT FLASH,MuxOneNAND area [027C0000-02CBFFFF] CMT FLASH,MuxOneNAND area [077C0000-07B3FFFF] CMT FLASH,MuxOneNAND area [010E0000-01EBFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 8443ECD5 [] sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 59.953 s Processing PPM file: rm721__11.40.ppm_b [BB5,XSR 1.6] size: 6.22 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 8.87 MB CMT FLASH,MuxOneNAND area [01EE0000-027BFFFF] Flash programming ... Programming completed in 12.828 s Processing CNT file: rm721__11.40_008.image_b_play_pl_v2_9j0g5 [BB5,XSR 1.6] size: 15.75 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 75.06 MB CMT FLASH,MuxOneNAND area [02CC0000-077BFFFF] Formating partition ... Flash programming ... Programming completed in 33.187 s Total time for flashing process(boot+erase+write) was 2 min 0.141 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: EDE6E82 Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: EDE6E82 Open device failed: FFFFFFFF (4) The system cannot open the file Warning: Phone did not reboot to normal mode. reheated combo flash,reheated pearl ic but no luck.any solution? |
mobile not get into local or test mode . use other software to check (infinity best) |
Phone type: RM-721 (Nokia C2-01) SW version: V 11.40 24-10-12 RM-721 (c) Nokia Imei plain: 35741804051776-8 Product code: 059G0G8 Battery voltage: 4822 mV, current: 82 mA Language Pack: - not available. SLPA ver[5]: PA_SIMLOC30 (20 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00IIIIRR0301035602, ver: 001.002 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 357418040517768 Version: SIMLOCK SERVER Provider: Orange Romania , Country: Romania Counter: 0/3, 0/10 CONFIG_DATA: 2261000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=22610F [Romania-Orange Romania ] phone goes to test mode but it has error on security.any way to solve this? |
and when i try to flash with fbus i get this MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C08175B0 Using device: HTI, FW ver: 00.50, SN: 0000684D Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Phone type: RM-721 (Nokia C2-01) SW version: V 11.40 24-10-12 RM-721 (c) Nokia ERROR: Packet Error(0xAA), code 0xC0000001 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! bot cable problem,tested 2 |
BLOCK1: 1=CLOSED(MCCMNC), DATA=22610F [Romania-Orange Romania ] Need unlock buy unlock code |
i dont need unlock for the phone!the problem is contact service after nokia logo! |
Nokia C2-01 Contact service Please Help I have also the same problem can any one have solution nokia c2-01 contact service issue :eek: |
Booting Phone via FBUS... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00000001 ID DWORD 3 : 020C1921 ID DWORD 4 : 02044100 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001051 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001060 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0D600110 ID DWORD 1 : 12255940 ID DWORD 2 : 0BA9CF24 ID DWORD 3 : A2E048EC ID DWORD 4 : 98E4A90D 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 67E82268 CRC 1 : F29CEA60 Checksum 14 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg Boot File - Version 012.08.00 Boot File - Revision 0x0003 (3) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0030 -> K5W1G13ACB Extended/Fixed ID : 0000 Revision ID : 0431 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 Checksum : 25 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0030 ExtID :0000 RevID :0431 Flash Descriptor Manufacturer Code : 00EC Device ID : 0030 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 08000000 (128 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_XSR17_alg.fg Algorithm File - Version 012.08.00 Algorithm File - Revision 0x0003 (3) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 =========================================== PHONE FIRMWARE VERSION: V 11.40 24-10-12 RM-721 (c) Nokia =========================================== VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Now Writing : CMT NPC Certificate 0x0400 Bytes NPC Write Successful... StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Now Writing : CMT CCC Certificate 0x0400 Bytes CCC Write Successful... StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Now Writing : CMT HWC Certificate 0x0400 Bytes HWC Write Successful... StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Now Writing : CMT R&D Certificate 0x0400 Bytes R&D Write Successful... Write Certificates OK! RPL Upload Finished!!! ================================================ Basic Phone Information ================================================ MCU Version: V 11.40 24-10-12 RM-721 (c) Nokia IMEI Plain : 357012049530342 IMEI Spare : A357012049530340 IMEI SV : 33570120495303476F Phone Model: Nokia C2-01 Category : Phone Phone Type : RM-721 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Long Production SN : 0 PPM SW Version : V 11.40 24-10-12 RM-721 (c) Nokia MR1 BT MCM Version : 1673-46038 MCU SW Version : V 11.40 24-10-12 RM-721 (c) Nokia RFIC Version : |Vapaus_6.5 | ??? DSP Version : SPR91_11.40 LCD Version : SEIKO Content Pack Version : Content: mr1_059Q2M5 V 11.40 24-10-12 RM-721 (c) Nokia AHNE Version : 41 RETU Version : 51 TAHVO Version : 00 Bluetooth ID : A8:E0:18:8B:71:02 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA VIII ================================================ Simlock Information ================================================ Unable to read SP Data.. ================================================ Basic Phone Information ================================================ MCU Version: V 11.40 24-10-12 RM-721 (c) Nokia IMEI Plain : 357012049530342 IMEI Spare : A357012049530340 IMEI SV : 33570120495303476F Phone Model: Nokia C2-01 Category : Phone Phone Type : RM-721 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Long Production SN : 0 PPM SW Version : V 11.40 24-10-12 RM-721 (c) Nokia MR1 BT MCM Version : 1673-46038 MCU SW Version : V 11.40 24-10-12 RM-721 (c) Nokia RFIC Version : |Vapaus_6.5 | ??? DSP Version : SPR91_11.40 LCD Version : SEIKO Content Pack Version : Content: mr1_059Q2M5 V 11.40 24-10-12 RM-721 (c) Nokia AHNE Version : 41 RETU Version : 51 TAHVO Version : 00 Bluetooth ID : A8:E0:18:8B:71:02 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA VIII ================================================ Simlock Information ================================================ Unable to read SP Data.. SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0301035602 DCC Ver: 001002 Status : OK ================================================== ==== Selected VPL File: RM721_059Q2M5_11.40_023.vpl ================================================== ==== Variant Details : RM-721 NDT APAC-MR1 LATIN DARK GREY Software Version : 11.40 Product Type : RM-721 Product Code : 059Q2M5 Variant Version : 023 |
plz any one help me how to solve |
Phone type: RM-721 (Nokia C2-01) SW version: V 11.40 24-10-12 RM-721 (c) Nokia Imei plain: 35701204953034-2 Battery voltage: 3632 mV, current: 80 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: NI00IIIIRR0301035602, ver: 001.002 SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! how to solve plz help |
SIMLOCK_DATA corrupted! not possible .......... |
you must write rpl if you do not have backup buy it Rpl file |
Rpl currupt. Buy rpl or flash the phone on a pc that have ever flashed it before it currupts. |
no way to solve this but..........one way i think only this to replace both power and flash ic. |
