Old 02-06-2014, 14:37   #1 (permalink)
ashuk deab nath's Avatar
Member: 1215691
Thanks Meter: 43
Unhappy Nokia C2-03 Big Problem..
Nokia C2-03 After few second restarting problem
here flash log...
MXKEY [USB Smart Card Reader 0], SN: C0872CD2
Using device: USB ROM
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: NMWCD, ver: 7.1.32.84
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.37
EBL version: Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 00EC 3012 - 23280002 [Samsung ]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI:
RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD__back.RPL"
Processing file: rm702__07.63.mcusw
Downloading item CODE:rm702__07.63.mcusw_ebl_psi.fls, num block: 4, size: 28 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.343 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.359 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.484 s
Erasing area 0x40280000-0x41D3FFFE ...OK
Programming completed in 34.875 s
Checksum verified (0x787E)
Processing file: rm702__07.63.ppm_i
Downloading item CUST[IMG]http://****************/images/smilies/001_tt2.gif[/IMG]ackage_i.ppm_ebl_psi.fls, num block: 1, size: 4.19 MB
Erasing area 0x41DC0000-0x421F1136 ...OK
Programming completed in 5.563 s
Checksum verified (0x844F)
Processing file: rm702__07.63.image_i_059H286
Downloading item CUST[IMG]http://****************/images/smilies/001_tt2.gif[/IMG]ackage_i_059H286.image.fls, num block: 1, size: 13 MB
Erasing area 0x424C0000-0x43E1FFFE ...OK
Programming completed in 17.765 s
Checksum verified (0xA624)
Total time for flashing process(boot+erase+write) was 3 min 2.532 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C2-03 USB Phonet, PORT_ID: 359065049884042
Verifying communication to device OK.
Phone type: RM-702 (C2-03)
SW version: V 07.63 17-08-12 RM-702 (c) Nokia
Imei plain: 35906504988404-2
Product code: 059D473
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: 06150123008027, ver:
Imei net: 35906504988404
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 0.094 s
*Flash latest verson flash file
*Clean and rehot pcb but same problem
Please help me
Old 02-06-2014, 16:13   #2 (permalink)
Member: 1215691
Thanks Meter: 43
Any solution.......??
Old 02-07-2014, 05:01   #3 (permalink)
Member: 1215691
Thanks Meter: 43
this is not solution any help sir......
Old 02-07-2014, 05:14   #4 (permalink)
sunilkumar70791's Avatar
Member: 1432329
Sonork: 100.1615863
Thanks Meter: 1,626
use atf flash ltest ver file
Old 02-07-2014, 06:42   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
If u have hwk try to flash on it ,hope u get success
post result
Old 02-07-2014, 07:11   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
Set restart with sim or without sim
remove sim and dial 112 , if still off than change pA
Old 02-08-2014, 04:37   #7 (permalink)
Member: 1215691
Thanks Meter: 43
flash hwk or mxbox but same problem
give me perfact solution
Old 02-08-2014, 04:59   #8 (permalink)
ashishsingh's Avatar
Member: 1424659
Sonork: 100.1648352
Thanks Meter: 142
http://forum.gsmhosting.com/vbb/f148...ution-1715218/
Old 02-08-2014, 06:47   #9 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
It restart with sim or without sim ?
Old 02-08-2014, 13:17   #10 (permalink)
Member: 1215691
Thanks Meter: 43
yes restart with sim or without sim
Old 02-08-2014, 13:18   #11 (permalink)
Member: 1215691
Thanks Meter: 43
not work..............
Last edited by ashuk deab nath; 02-08-2014 at 13:19. Reason: not work..............
Old 03-19-2014, 15:10   #12 (permalink)
Member: 1888830
Thanks Meter: 4
local mode probalam not solov plz help meee
Old 03-19-2014, 15:11   #13 (permalink)
Member: 1888830
Thanks Meter: 4
Old 03-19-2014, 15:26   #14 (permalink)
Member: 2141811
Thanks Meter: 38
Flash ur device with right flash file
Sent from my iris458Q using Tapatalk
Page generated in 0.21774 seconds with 8 queries
