Old 07-04-2013, 11:46   #1 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
nokia 5233 battery draine problem-......
I have a set nokia5233 .no any shorting in set but battery backup only 3 or 4 hours. On charging set get heating. I changed both power ic and also removed Bluetooth ic but same in conditions.anyone have sure solution. Please read carefully my post before any reply. Thanks.
Old 07-04-2013, 12:28   #2 (permalink)
Absar_Global's Avatar
Member: 1442705
Thanks Meter: 1,061
bro change P.A and post result
Absar_Global
Old 07-04-2013, 18:54   #3 (permalink)
Member: 1891165
Thanks Meter: 2
First chek without sim card if your set doesn't drain battery it means pfo problem then change pfo . If same condition without sim card it means PCB problem.may be any resistance short or open. Findout and remove or replace that which is neccessory according to condition.
The Following User Says Thank You to shageer imran For This Useful Post:
Old 07-04-2013, 19:07   #4 (permalink)
Member: 1722956
Thanks Meter: 305
Yes you are Right. I think so but it drains battery without sum card and getting heating on charging.tell me right solution.
Old 07-04-2013, 19:51   #5 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
connect mobile with external psu & measure current consumption then post here d result .
u may also open mobile then connect it to external psu & measure by finger which parts getting hot .
post result
Old 09-04-2014, 05:28   #6 (permalink)
Member: 1963898
Thanks Meter: 52
post result
i checked the phone in external analyser cpu goes hot ....what happen
Page generated in 0.15767 seconds with 9 queries
