Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2011
Member: 1527420 Status: Offline Thanks Meter: 13 | nokia c2-03 keypad problem |
![]() | #2 (permalink) |
Moderator ![]() Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,118 | first try to remove d marked varistor (first picture) V2407,V2408,V2409 then check , if same remove d marked parts (second & third picture) R2411,R2412,R2413,R2414,R2415,R2417 then check . post d result here . |
![]() | #5 (permalink) |
Major Poster ![]() ![]() Join Date: Sep 2011
Member: 1663259 Status: Offline Thanks Meter: 1 | my board is also not ok........... still same pro,,,,,, may be board pro its has been already worked by other mech........ any way thank you........ i will check to any other board............ |
![]() | #13 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: cambodia
Member: 578236 Status: Offline Thanks Meter: 29 | Quote:
thanks SARCAR very much today i met one also i try remove many thing like volum up ky+volum down key, lock key and 3 varisters , it is not solved but I try to follow your 2nd page by removing the 3 Resistors then ok thankssssssssss from cambodia | |
![]() | #14 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2013 Location: palani. tamilnadu
Member: 1862407 Status: Offline Sonork: india Thanks Meter: 36 | Quote:
![]() | #15 (permalink) |
Junior Member Join Date: Aug 2013
Member: 1997335 Status: Offline Thanks Meter: 0 | Hai I removed the components. As you marked for c2-03 for keypad not working and I removed vol keys and lock switch but still same problem I rehoted the power ic. But no use please help me some what can I do |
