Old 08-20-2012, 11:32   #1 (permalink)
GAURAV-MOBILE's Avatar
Member: 1798882
Thanks Meter: 145
Arrow Nokia C2-05 Hardware Solution
Nokia C2-05 Insert Sim Solution
This post holds Nokia C2-05 Insert Sim Problem Solution. If you are having one of these problems check these images out and do this simple solution.
Nokia C2-05 Sim Ic Jumper
Nokia C2-05 Sim Track Ways
Just see the solution preview below for it shows which track to be check and make jumper.
The Following User Says Thank You to GAURAV-MOBILE For This Useful Post:
Old 08-20-2012, 11:35   #2 (permalink)
Member: 1798882
Thanks Meter: 145
Thumbs up Nokia C2-05 Hardware Solution
Nokia C2-05 Mic Problem Solution
This post holds Nokia C2-05 Mic Problem Solution. If you are having one of these problems check these images out and do this simple solution.
Nokia C2-05 Mic Solution
Nokia C2-05 Microphone Solution
Nokia C2-05 Mic Track Ways Jumper
Nokia C2-05 Mic Not Working
Old 08-20-2012, 11:38   #3 (permalink)
Member: 1798882
Thanks Meter: 145
Nokia C2-05 Ringer Problem Solution
This post holds Nokia C2-05 Ringer Not Working Problem Solution. If you are having one of these problems check these images out and do this simple solution.
Nokia C2-05 Ringer Jumper
Nokia C2-05 Ringer Solution
Nokia C2-05 Ringer Track Ways
Nokia C2-05 Speaker Solution
Old 08-20-2012, 11:42   #4 (permalink)
Member: 1798882
Thanks Meter: 145
Nokia C2-05 MMC Problem Solution
This post holds Nokia C2-05 Mmc Problem Solution. If you are having one of these problems check these images out and do this simple solution.
Nokia C2-05 Mmc Solution
Nokia C2-05 Mmc Not Working
Nokia C2-05 Mmc Ic Solution
Old 08-20-2012, 11:44   #5 (permalink)
Member: 1798882
Thanks Meter: 145
Nokia C2-05 Display Problem Solution
This post holds Nokia C2-05 Display Problem Solution. If you are having one of these problems check these images out and do this simple solution.
Nokia C2-05 White Lcd
Nokia C2-05 Blank Display
Nokia C2-05 Display Solution
Nokia C2-05 Display Not Working
Old 08-20-2012, 11:47   #6 (permalink)
Member: 1798882
Thanks Meter: 145
Nokia C2-05 On/Off Way Solution
This post holds Nokia C2-05 On Off . If you are having one of these problems check these images out and do this simple solution.
Nokia C2-05 On Off Switch Solution
Nokia C2-05 On Off Solution
Nokia C2-05 On Off Jumper
Nokia C2-05 On Off Track Ways
Nokia C2-05 On Off Problem
The Following 3 Users Say Thank You to GAURAV-MOBILE For This Useful Post:
Old 01-12-2013, 17:23   #7 (permalink)
cbcelular's Avatar
Member: 217679
Thanks Meter: 78
Question
I need a solution for nokia C2-05 without lighting the display. please
The Following User Says Thank You to cbcelular For This Useful Post:
Old 05-29-2013, 16:23   #8 (permalink)
عمادالعمده's Avatar
Member: 903681
Thanks Meter: 28
i nead speak jumper flat
Old 10-20-2013, 16:18   #9 (permalink)
Member: 1728072
For GURAV-MOBILE, about nokia C2-05 display soution
!!!this is 24 pin keypad IC not display IC!!!
Old 09-19-2014, 09:27   #10 (permalink)
Member: 1305225
Thanks Meter: 18
of which memory ic works in this .....og 5130 or c1
Old 09-21-2014, 12:22   #11 (permalink)
Member: 1728072
You can try 5130 or 6300 memory ic (it's a long time from when I change an memory ic).
My advise is to buy a new one because a second hand ic may not work properly, if you don't have mach experience.
Old 09-25-2014, 12:58   #12 (permalink)
Member: 1669249
Thanks Meter: 13
Thumbs down
need c2-05 white secend on 2secend auto off problem
The Following User Says Thank You to asirmobile For This Useful Post:
Old 03-15-2015, 03:57   #13 (permalink)
Member: 2351178
Sonork: 1000.1667232
Thanks Meter: 2
I need network track.
Old 02-12-2017, 13:53   #14 (permalink)
Member: 2098116
Sonork: taposhmobile
Thanks Meter: 4,294,967,266
not working..........................
Old 02-12-2017, 13:54   #15 (permalink)
Member: 2098116
ok file with the full flash..........
The Following 2 Users Say Thank You to taposhmobile For This Useful Post:
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.42370 seconds with 8 queries
