Nokia C2-05 no power Please Help Nokia c2-05 Dropped on the floor does not power on any more I've folowed power switch ways solution no use The Phone draws about 20 ma on 4.1V on the power supply but the current stays as it and the phone not powered please help |
Nokia C2-05 power switch way http://forum.gsmhosting.com/vbb/f148...tions-1690951/ salina rai 9741081772 |
I've tried that still dead |
nokia c2-05 crashed into the floor try unloading its handset pcb remove it from the casing see which components or broken shift when consumption 20 mAh handset certainly short-circuited 1.coba injectable use handset with a voltage of 1 volt psu to 3.7 v and touch where the hot component if not that hot ... try rehot its handsets with low temperature 2.handset die from falls possibility ic power ic and pa but if see consumption above the analysis is faulty software .. Will do his version of the program and the type of the current version up grade |
