08-01-2013, 13:11 | #1 (permalink) |
Freak Poster Join Date: Aug 2002 Age: 52
Member: 14857 Status: Offline Thanks Meter: 4 | Nokia C2-05 no power Please Help The Phone draws about 20 ma on 4.1V on the power supply but the current stays as it and the phone not powered please help |
08-01-2013, 13:17 | #2 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,078 | Nokia C2-05 power switch way http://forum.gsmhosting.com/vbb/f148...tions-1690951/ salina rai 9741081772 |
08-02-2013, 07:47 | #4 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
nokia c2-05 crashed into the floor try unloading its handset pcb remove it from the casing see which components or broken shift when consumption 20 mAh handset certainly short-circuited 1.coba injectable use handset with a voltage of 1 volt psu to 3.7 v and touch where the hot component if not that hot ... try rehot its handsets with low temperature 2.handset die from falls possibility ic power ic and pa but if see consumption above the analysis is faulty software .. Will do his version of the program and the type of the current version up grade | |
