nokia c5 solution here . Nokia C5-00 USB Device Not detected Problem Solution https://lh3.googleusercontent.com/-V...d+Solution.jpg |
Nokia C5-00 Keypad white LED light not working problem solution https://lh3.googleusercontent.com/-l...++Solution.jpg |
Nokia C5 Camera Flash Light LED problem Solution https://lh5.googleusercontent.com/-t...m+solution.jpg |
Nokia C5 MMC microSD Not detected, insert memory card error problem solution Troubleshooting hints for Nokia C5 memory card problem:https://lh5.googleusercontent.com/-j...m+solution.jpg 1. Try to use and replace another working microSD card. 2. Clean the microSD card holder if oxidized. 3. Check the VMEM voltage this reads from 1.8v to 3V. 4. Check replace the 47 ohms resistors and 18p and 100n capacitors. 5. If the above procedures didn't work, try to restore, flash update the device firmware. 6. If the firmware is okay. the possible faulty is the GAZOO IC. Reworking or replacing it will only fix the problem. |
Repair hints for not working camera on Nokia C5: 1. Remove the camera module, clean the socket or holder pins if oxidized. 2. Check the VCAM 1.8V and 2.8V on across to the highlighted filter coils and capacitors. Check/replace also those coils. 3. If the voltage is missing or there is no readings, check the VBAT 3.8 volts 4. If the VBAT voltage is okay, replace the regulator IC on a specific voltage that has no readings. 5. Replace the camera module |
Nokia C5 keypad not responding - connection tracing repair solution [IMG]http://2.bp.********.com/_haRAPmO1Seg/TMUsqjL-J4I/AAAAAAAAAqI/JiUtlAjCVc8/s320/nokia+c5+keypad+full+ways+tracks+solution.jpg[/IMG] |
Nokia C5 Microphone Failure Repair Solution [IMG]http://2.bp.********.com/_haRAPmO1Seg/TML7MXYdNZI/AAAAAAAAApA/1rNaRT7YBgQ/s320/C5+Mic+problem+solution.jpg[/IMG] |
No Earpiece Speaker Audio Sound |
Nokia C5 Charger Not supported problem solution https://lh5.googleusercontent.com/-Y...d+solution.jpg |
good good work bro keep it up |
c5 singnal prob no network found plz help |
